Is this UEM problem or still software problem??? 1st Log after RPL ASIC ID: 0x1120 [UPP8M_v3.0 ] u_2nd.fia: [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D3B847:2984DA60 ASIC type: 2 UEM Imei: 31078020147845 Flash Imei: 31078020147845 MasterCode: 0357672015 RPL backup saved to "C:\mobileEx\3.0\data\backup\31078020147845_back.r pl" Phone Type: RH-19 (Nokia 3100) SW Version: V 06.11 17-05-05 RH-19 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 31078020147845 Product Code: 0511598 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: V Language Pack: English,Chinese S,Chinese T,Bahasa Ind Imei plain is invalid !!! Counter: 0/3, 0/10 CONFIG_DATA: 70ADB71AC9763866 PROFILE_BITS: 13BC65B7D1EAF782 SIMLOCK_DATA corrupted! 2nd Log after full erase,full flashed,reset data1 and rpl ASIC ID: 0x1120 [UPP8M_v3.0 ] u_2nd.fia: [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D3B847:2984DA60 ASIC type: 2 UEM Imei: 31078020147845 Connecting to server ...OK, Login ... Hello hape_rpl, you have 80 credits left. RPL backup saved to "C:\mobileEx\3.0\data\backup\RPL\31078020147845.RP L" ASIC ID: 0x1120 [UPP8M_v3.0 ] u_2nd.fia: [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-19 (Nokia 3100) SW Version: V 06.31 25-11-05 RH-19 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 31078020147845 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: V Language Pack: English,Chinese S,Chinese T,Bahasa Ind Maybe someone can help me solve this??? :confused::confused::confused: Thx |
You must change UEM IC |
For analysis only When to write RPL or When to Change UEM IC if you red this UEM Imei : 31078020147845 Flash Imei: 31078020147845 1.READ ASK IMEI You may to cross-check w/ IMEI STICKER If small different EXAMPLE like this : UEM Imei : 31078020147845 STICKER Imei: 35078020147845 that mean any problem w/ HARDWARE, mostly UEM. and must change UEM NOT Write RPL Bcz UEM IMEI has changed. OTP (One Time Programable)= that Mean UEM IMEI area, just one times to write, NO MORE. actually RPL just write IMEI on the FLASH iC only, if UEM has IMEI (NOT EMPTY). If UEM empty (NEW UEM), mean RPL writen on UEM area adn FLASH IC area. ================================================== ======================================= for this case UEM Imei : 31078020147845 Flash Imei: 31078020147845 that mean UEM damage, but some one still read ask n write RPL to it.. finnaly you get mobile-phone still abnormal. B.R. |
