Old 03-19-2009, 08:51   #1 (permalink)
Member: 82073
Thanks Meter: 10
Unhappy Is this UEM problem or still software problem???
1st Log after RPL
ASIC ID: 0x1120 [UPP8M_v3.0 ]
u_2nd.fia: [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
u_amd.fia: [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 00D3B847:2984DA60
ASIC type: 2
UEM Imei: 31078020147845
Flash Imei: 31078020147845
MasterCode: 0357672015
RPL backup saved to "C:\mobileEx\3.0\data\backup\31078020147845_back.r pl"
Phone Type: RH-19 (Nokia 3100)
SW Version: V 06.11 17-05-05 RH-19 (c) Nokia.
Imei plain: ??????????????-?
Imei OTP: 31078020147845
Product Code: 0511598
Cellular System: GSM
ASIC ID: 0x1120, type: 2
Ppm Id: V
Language Pack:
English,Chinese S,Chinese T,Bahasa Ind
Imei plain is invalid !!!
Counter: 0/3, 0/10
CONFIG_DATA: 70ADB71AC9763866
PROFILE_BITS: 13BC65B7D1EAF782
SIMLOCK_DATA corrupted!
2nd Log after full erase,full flashed,reset data1 and rpl
ASIC type: 2
Connecting to server ...OK, Login ...
Hello hape_rpl, you have 80 credits left.
RPL backup saved to "C:\mobileEx\3.0\data\backup\RPL\31078020147845.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
SW Version: V 06.31 25-11-05 RH-19 (c) Nokia.
Ppm Id: V
Language Pack:
Maybe someone can help me solve this???
Thx
Old 03-19-2009, 09:08   #2 (permalink)
Member: 705101
Thanks Meter: 17
Smile
Originally Posted by tenso View Post
1st Log after RPL
ASIC type: 2
Ppm Id: V
Language Pack:
Counter: 0/3, 0/10
ASIC type: 2
Ppm Id: V
Language Pack:
Thx
You must change UEM IC
The Following 2 Users Say Thank You to bebenatower For This Useful Post:
Old 03-25-2009, 06:51   #3 (permalink)
Member: 616091
Thanks Meter: 27
For analysis only When to write RPL or When to Change UEM IC
if you red this
UEM Imei : 31078020147845
1.READ ASK IMEI
You may to cross-check w/ IMEI STICKER If small different
EXAMPLE like this :
STICKER Imei: 35078020147845
that mean any problem w/ HARDWARE, mostly UEM. and must change UEM NOT Write RPL
Bcz UEM IMEI has changed.
OTP (One Time Programable)= that Mean UEM IMEI area, just one times to write, NO MORE.
actually RPL just write IMEI on the FLASH iC only, if UEM has IMEI (NOT EMPTY).
If UEM empty (NEW UEM), mean RPL writen on UEM area adn FLASH IC area.
for this case
that mean UEM damage, but some one still read ask n write RPL to it.. finnaly you get mobile-phone still abnormal.
B.R.
The Following User Says Thank You to cxacxa For This Useful Post:
Is This List Right Or No aliwali The Market Feed Back 24 10-13-2005 18:18
IS this a bug or error to Nokia 8250? mygod100 Sim Cloning and Scaning 0 04-13-2004 05:18
Is this C55 unlocked or what? :) cloverleaf E-Gold Based Phones 1 03-15-2004 19:02
what is this animal... v66_8mb or V66i ? nikist Motorola P2k 3 01-22-2004 20:23
Page generated in 0.25015 seconds with 8 queries
