Old 12-09-2010, 05:19   #1 (permalink)
Member: 1012165
Thanks Meter: 116
help problem flashing n900
help bro problem flashing n900 with mx-key ,it does not flash when i select only mcu,click flash then hold down u key till usb shows at right corner it just shows comleted without the phone flashing pls help log below
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Remove USB cable from device.
Turn off the phone
Press and hold down key 'u'
Connect USB cable between the phone and host PC while still holding down key 'u'
When USB cable gets connected it powers the phone and set's it to flashing mode
Waiting for phones to boot up ...
Flashing completed in 1 min 24.579 s
Phone not responding !
when i try to use meamo flasher dont understand the part where i am suppposed to type flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_PR_COMBINED_MR0_ARM.bin -f -R on command prompt
is it constant or it changes with the flash file i am using cos the flash file i downloaded is in exe file and its version 10 i.e Nokia N900 RX-51 Gr.RUS_sw-10.2010.19.1_v4.0 pls help how do i go about this?
Old 12-09-2010, 05:27   #2 (permalink)
reyfer24's Avatar
Member: 1044690
Sonork: 100.1617308
Thanks Meter: 56
Originally Posted by tonywireless View Post
help bro problem flashing n900 ,it does not flash when i select only mcu,click flash then hold down u key till usb shows at right corner it just shows comleted without the phone flashing pls help log below
Turn off the phone
I know we're talking in the section of the mx key, but even that has its drawbacks mxkey to flash the N900 model, I recommend you follow this tutorial and you'll do better:
1: Download and install maemo and copy into maemo installation folder (C: \ Program Files \ maemo \ flasher-3.5) to install the bin file (the downloaded file even navifirm)
2: open maemo flasher 3.5 (you can do from start / all programs / maemo / maemo flasher3.5) "it appears automatically after you install maemo"
3: write exactly maemo open spaces and even the case this command: flasher-3.5-F "exact file name that charge even with the extension it would be. Bin" f-R "enter"
typing the exact command would look like:
flasher-3.5-F RX-51_2009SE_2.2009.51-1.002_PR_F5_002_ARM.bin-f-R "enter"
4: remove battery, put it back, push button "or" connect the USB cable and now begins to flash software
5: wait the end of flash!
maemo flasher 3.5: tablets-dev.nokia.com restricted downloads
The Following User Says Thank You to reyfer24 For This Useful Post:
Old 12-09-2010, 05:42   #3 (permalink)
Member: 1012165
Thanks Meter: 116
thanks for ur assistance but this is what i get when i tried it pls help me know what is wrong Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\maemo\flasher-3.5>flasher-3.5-f RX-51_2009SE_10.2010.19-1_PR_CO
MBINED_MR0_ARM.bin-f-r
'flasher-3.5-f' is not recognized as an internal or external command,
operable program or batch file.
C:\Program Files\maemo\flasher-3.5>flasher-3.5-F RX-51_2009SE_10.2010.19-1_PR_CO
MBINED_MR0_ARM.bin-f-R
'flasher-3.5-F' is not recognized as an internal or external command,
Old 12-09-2010, 05:46   #4 (permalink)
reyfer24's Avatar
Member: 1044690
Sonork: 100.1617308
Thanks Meter: 56
Here you can clarify your questions:
http://forum.gsmhosting.com/vbb/f299...roblem-925841/
Old 12-09-2010, 06:24   #5 (permalink)
Member: 1012165
Thanks Meter: 116
i eventually flashed it successfully the error i made was 1 there is supposed to be
a space between 3.5 and -5 i.e 3.5 -5 not 3.5-5 2. space between .bin and -f and -R at the end .
but now the challenge i am having now is that when i try to perform operation like geting started and opening camera it says
it shows not enough memory to to open camera pls help
C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_C
flasher v2.5.2 (Sep 24 2009)
SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0
Image 'kernel', size 1705 kB
Version 2.6.28-20101501+0m5
Image 'rootfs', size 173568 kB
Version RX-51_2009SE_10.2010.19-1_PR_MR0
Image 'cmt-2nd', size 81408 bytes
Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
Version BB5_09.36
Image 'cmt-mcusw', size 5826 kB
Version rx51_ICPR82_10w08
Image '2nd', size 14720 bytes
Valid for RX-51: 2217, 2218, 2219, 2220, 2120
Version 1.4.14.8+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
Valid for RX-51: 2101, 2102, 2103
Image '2nd', size 14848 bytes
Valid for RX-51: 2307, 2308, 2309, 2310
Valid for RX-51: 2407, 2408, 2409, 2410
Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306
Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406
Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2
113, 2114, 2115, 2116, 2117, 2118, 2119
Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506
Valid for RX-51: 2607, 2608, 2609, 2610
Valid for RX-51: 2507, 2508, 2509, 2510
Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2
210, 2211, 2212, 2213, 2214, 2215, 2216
Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606
Suitable USB device not found, waiting.
USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0
Sending xloader image (14 kB)...
100% (14 of 0 kB, avg. 14 kB/s)
Sending secondary image (106 kB)...
100% (106 of 0 kB, avg. 106 kB/s)
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
100% (79 of 0 kB, avg. 79 kB/s)
Sending cmt-algo image (507 kB)...
100% (507 of 0 kB, avg. 507 kB/s)
Sending cmt-mcusw image (5826 kB)...
100% (5826 of 0 kB, avg. 5826 kB/s)
Flashing cmt-mcusw... done.
Sending kernel image (1705 kB)...
100% (1705 of 0 kB, avg. 1705 kB/s)
Flashing kernel... done.
Sending and flashing rootfs image (173568 kB)...
100% (173568 of 0 kB, avg. 173568 kB/s)
Finishing flashing... done
Erasing CMT: 46%Sending request 0x12 failed: No error
Old 12-09-2010, 06:29   #6 (permalink)
Member: 1012165
Thanks Meter: 116
i just noticed the error with the erasing cmt is it normal?
Old 12-09-2010, 07:03   #7 (permalink)
Member: 1012165
Thanks Meter: 116
i flashed again and the cmt was flashed successfully but still not enough memory to open camera pls help. log below
Version BB5_09.36
105.
NOLO version 1.4.14
Version BB5_09.36
Version BB5_09.36
105.
NOLO version 1.4.14
CMT flashed successfully
Old 12-09-2010, 08:04   #8 (permalink)
Member: 1012165
Thanks Meter: 116
after successfully flash n900 now it cannot open camera it says not enough memory to open camera,when i put it on mass storage it no longer shows but it was showing before flashing and before flashing it was working just that after snapping it cannot save it says operation failed,also the dialed numbers could not show when u check them but now they record dailed numbers
Old 12-09-2010, 09:21   #9 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Thumbs up just use this method i mentioned ...
http://forum.gsmhosting.com/vbb/f299...ml#post6474347
use this files and cmd's bro.... first use -f only ... then second time use -r only that's all it's the trick ...
Old 12-09-2010, 09:49   #10 (permalink)
Member: 1012165
Thanks Meter: 116
thanks bro but i flashed f suceessfully but when i try to flash r i get this error
what do i do?
OMBINED_MR0_ARM.bin -R
Version BB5_09.36
Version BB5_09.36
105.
NOLO version 1.4.14
C:\Program Files\maemo\flasher-3.5>^A
Old 12-09-2010, 10:29   #11 (permalink)
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
contact me on yahoo ....
what do i do?
Version BB5_09.36
Version BB5_09.36
105.
NOLO version 1.4.14
mind one thing don't remove the device while try to second file ...
Old 12-10-2010, 09:26   #12 (permalink)
Member: 1012165
Thanks Meter: 116
help all after flashing n900 now camera cannot open it writes not enough memory to open camera also when i click on the get started it writes operation temporarily disabled due to low memory,
Old 12-10-2010, 20:31   #13 (permalink)
Member: 1012165
Thanks Meter: 116
pls help i have upgraded the phone to version 20 using this file RX-51_2009SE_20.2010.36-2.002_PR_COMBINED_002_ARM but still yet camera does not open it still says not enough memory what do i do pls
Old 12-15-2010, 05:49   #14 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
Successful eMMC Flash can solve this problem. I tried in many windows but never succeed. but later i did with Linux. phone is perfectly working with Fresh MMC storage.
Old 12-17-2010, 23:34   #15 (permalink)
Member: 1216342
i have same problem did you find solution.
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.46966 seconds with 10 queries
