Old 03-28-2010, 14:47   #1 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Unable to Rebuild IMEI 6020 (?????????????)
ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 882E [ST M58LR128GU,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
Performing Flash Authentication ...OK
UEM ID: 009D5A0D:2984DA60
ASIC type: 2
UEM Imei: 35307501919958
Connecting to server ...OK, Login ...
Hello C080C24E, you have 2010 credits left.
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35307501919958.RP L"
Programming FLASH Imei ...failed
Phone Type: RM-30 (Nokia 6020)
SW Version: V 04.90 09-05-06 RM-30 (c) Nokia.
Imei plain: 35307501919958-2
Imei OTP: 35307501919958
Product Code: 0535082
Cellular System: GSM
ASIC ID: 0x2142, type: 2
Ppm Id: G
Language Pack:
English,French,German,Spanish,Arabic,Urdu,Farsi
Imei net: 35307501919958
Version: SIMLOCK SERVER VERSION 58
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Old 03-28-2010, 15:31   #2 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
all job done
ASIC type: 2
Ppm Id: G
Language Pack:
Counter: 0/3, 0/10
all job has been done just reset all .... ur porblem will b solved
Old 03-28-2010, 15:35   #3 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
is done.... unlock ur phone again an it should work fine
Old 03-29-2010, 11:59   #4 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
But phone off after 30 seconds
Old 03-29-2010, 17:12   #5 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Getting same problem again and again
ASIC type: 2
Ppm Id: G
Language Pack:
Counter: 0/3, 0/10
Old 03-29-2010, 17:40   #6 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
u try nre update ????????????
Old 03-29-2010, 17:59   #7 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Yes i updated too but same problem since 3 days.
Old 03-29-2010, 18:12   #8 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Thanks Meter: 94
See last digits of IMEI label. Maybe different. Today i repair 1650 and failed to program imei but last digits of IMEI is same with label. Try to change flash IC.
Old 03-31-2010, 17:14   #9 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
I installed version 1.6 but same error
ASIC type: 2
Ppm Id: G
Language Pack:
Counter: 0/3, 0/10
Old 03-31-2010, 18:26   #10 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Help..................................
Old 04-01-2010, 00:51   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
your phone IMEI already fixing
Ppm Id: G
Language Pack:
Counter: 0/3, 0/10
why you need rewrite again ??
i thinks must use (reset data1) and erase full flash
after flashing with ordinary frimware (erase whole flash -> ticked ) rewrite your imei
br,
Help to rebuild IMEI on same phones!?!?! Maurone UST Pro II 4 03-09-2006 09:40
How to rebuild imei in a panasonic gd55? mitchbuchanan Panasonic 3 02-24-2006 18:18
7260, RM-17 How to rebuild IMEI...? omega_plus UFS2 + UFS3-Tornadoflasher 7 01-17-2006 17:57
Newest Griffin 2.895 unable to rebuild IMEI on DCT3 phones... byteforce Griffin 2 05-27-2005 18:12
How to rebuild IMEI in NOKIA DCT4 ? GSM SNIPER UFS2 + UFS3-Tornadoflasher 4 11-05-2004 21:26
Page generated in 0.26930 seconds with 10 queries
