Old 02-18-2010, 18:56   #1 (permalink)
eman_sayed55's Avatar
Member: 850081
Thanks Meter: 15
unlock 2680s
unlock 2680s ?????????????
The Following User Says Thank You to eman_sayed55 For This Useful Post:
Old 02-18-2010, 18:57   #2 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,972
yes u can unlock
this model on mxkey
Old 02-18-2010, 18:57   #3 (permalink)
Member: 888048
Sonork: 123
Thanks Meter: 30
Its ok to unlock.................................
Old 02-18-2010, 19:33   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
depend on your phone frimware version
 -2680 (RH-392) -> V04.56,V04.91,V05.28,V56.17,V06.17
 -2680s-2b (RH-393) -> V04.56,V56.17
must reflash first if phone version not match with frimware supported list
br,
Old 02-18-2010, 19:45   #5 (permalink)
Member: 4813
Thanks Meter: 400
br,
o no,no need to reflash - with mx v3.3 rev1.6 unlock is impossible, only with mx v3.2 rev5.4 is possible ( tested with HWK and Jaf boxes). After mx 3.2 rev5.4 all other updates is bad to unlock for dct4+ ( also tested with hwk and jaf)
The Following 2 Users Say Thank You to raychevski For This Useful Post:
Old 02-18-2010, 20:56   #6 (permalink)
Member: 867007
Thanks Meter: 42
i just unlocked a 2680s (rm-392 v.4.91) today with mxkey 3.3 rev1.6p without problems, first time failed to unlock but second time after selected ASIC 11 in unlock tab the phone was unlocked. (using UFS as interface).
Old 02-18-2010, 21:09   #7 (permalink)
Member: 4813
Thanks Meter: 400
for v.491 no problem - test with vers. 528 or 617 and see - BAD UNLOCK
test and post result
Old 02-18-2010, 21:20   #8 (permalink)
Member: 4813
Thanks Meter: 400
only mx v3.2 rev5.4 give good result to unlock for dct4+
Old 02-18-2010, 21:48   #9 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
Flash and unlock your mobile
Old 02-25-2010, 13:04   #10 (permalink)
Member: 1015645
Thanks Meter: 113
any body tested that model plz post log
Old 02-26-2010, 10:13   #11 (permalink)
Member: 241650
Thanks Meter: 71
I tried unlock v05.28 and the phone turn dead. flashed it with v04.91 and all was OK.
Old 02-26-2010, 10:19   #12 (permalink)
Member: 1028392
Thanks Meter: 87
i already flashed it with 5-6 different flash, with some of them no network, also i can't change the language , can't get ppm from phoenix flash.
Old 02-26-2010, 11:17   #13 (permalink)
Member: 241650
Thanks Meter: 71
Just flash it with version 04.91 because later versions are still not possible instead you got a dead phone after unlock.
Old 02-26-2010, 11:21   #14 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 810
you can unlock with cyclon in minets testid for me many time
with mx some annon prablom
Old 02-26-2010, 12:13   #15 (permalink)
Member: 4813
Thanks Meter: 400
mobileEx 3.2 rev5.4
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35687402995812_BA CK.rpl"
Processing file: rm392__06.17.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 11.81 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548
Performing Flash Authentication ...OK
UEM ID: 0002348A:3B8ADA60
Area [01000000-0101FFFF] erased in 1.172 s
Area [01020000-01CFFFFF] erased in 2 min 0.281 s
Flash programming ...
Programming completed in 1 min 11.609 s
File Processed in 3 min 22.515 s
Processing file: rm392__06.17_ISM_002.image_ek_globul_bg_grey as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.88 MB
UEM ID: 0002348A:C5A4DA78
Area [02180000-02E7FFFF] erased in 4 min 0.078 s
Area [02E80000-02FBFFFF] erased in 23.282 s
Converting UCP blocks to 128 K.
Programming completed in 25.359 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.016 s
File Processed in 5 min 10.531 s
Processing file: rm392__06.17.ppm_ek as PPM
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH - COMBO FLASH - COMBO FLASH
UEM ID: 0002348A:2984DA60
Area [01D00000-0217FFFF] erased in 56.359 s
Programming completed in 13.703 s
File Processed in 1 min 17.094 s
Flashing completed in 10 min 8.078 s
After Flash Processing ...
Updating Product Code OK.
Reseting Factory Values OK.
PhoneType:RM-392
SwVersion: V 06.17 10-03-09 RM-392 (c) Nokia
MCU file: rm392__06.17.mcusw
Trying to find patch position ...OK, case id: 4
ROM version: 3
Area [01000000-0101FFFF] erased in 1.187 s
Area [01080000-0109FFFF] erased in 1.188 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Area [01080000-0109FFFF] erased in 1.187 s
Programming ...
Completed in 44.672 s
Phone Type: RM-392 (Nokia 2680s)
SW Version: V 06.17 10-03-09 RM-392 (c) Nokia
Imei plain: 35687402995812-9
Imei OTP: 35687402995812
Product Code: 0579757
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: EK
Language Pack:
English,Bulgarian,German
Imei net: 35687402995812
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 11 min 6.796 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 5.985 s
mobileEx 3.3 rev1.6 is bad for unlock
unlock 2680s 5.28 not unlock gadzetxp Cyclonebox 3 04-01-2009 23:58
Unlock 2680s problem artech2 J.A.F. Plus 1 01-18-2009 01:23
how to unlock 2680s-2? neoBIT666 HWK 2 11-14-2008 15:03
Page generated in 0.43989 seconds with 8 queries
