Old 03-05-2010, 05:40   #1 (permalink)
Member: 752215
Thanks Meter: 21
Updating SIMLOCK...error 0x1
Hi,
Unlocking 3120c error is this
Is this server problem..or bug....
now phone has SIMLOCK_DATA corrupted!
any solution.....
Old 03-05-2010, 06:03   #2 (permalink)
Member: 1021855
Sonork: BLACKBERRY INSIDE
Thanks Meter: 600
hi restore back up rpl imie then unlock again init simlock..
any way server is online working for me
Imei net: 359318020343631
Version: SIMLOCK SERVER
Provider: Smart Communications, Country: Philippines
Counter: 0/3, 0/10
CONFIG_DATA: 5150300000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 51503F, DATA=51503F
BLOCK 2: 1=LOCKED (MCC+MNC): 51503F, DATA=51503F
Backup saved to "BB5_35931802034363_SIMLOCK.back"
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V ICPR71_08w44.1 30-10-08 RM-450 (c) Nokia
ApeCoreSw: 100.21.110
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: 4B9B75103E691FF8
Calculating NCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
#pw+ 272855893898714 +1 #
#pw+ 346709586995603 +2 #
#pw+ 748116776343359 +3 #
#pw+ 462166921868586 +4 #
#pw+ 069890353973762 +5 #
#pw+ 498636114055612 +6 #
#pw+ 906714964576146 +7 #
Sending NCK code ...
Trying NCK lock 7 ... OK: code accepted.
Completed in 20.953 s
Restarting phone ...
Reading Simlock info ...
Counter: 0/3, 0/10
BLOCK 1: 1=OPEN, DATA=51503F
BLOCK 2: 1=OPEN, DATA=51503F
unlock via codes e63
Old 03-05-2010, 06:04   #3 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,896
Originally Posted by Mr.Furious View Post
Hi,
any solution.....
Wait for new update this error have in mxkey
Old 03-05-2010, 06:06   #4 (permalink)
Member: 1248625
Thanks Meter: 7
Hi,
any solution.....
hi fren.... restore simlock backup....
unlock by code with mx key...
luck...
br.
The Following User Says Thank You to ozora For This Useful Post:
Old 03-05-2010, 06:12   #5 (permalink)
Member: 752215
Thanks Meter: 21
same error while trying to restore simlock backup
Old 03-05-2010, 06:13   #6 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 810
Hi,
any solution.....
hello
1 use jaf interface with mx
2 see this guide your fone
(bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>>
repair sd ) now go to pm section only super sd auth betan clik
now selact>> pm lord from file>>pm auth>> write pm
now your fone is ok insha****************
The Following User Says Thank You to naveedbutt For This Useful Post:
Old 03-05-2010, 06:15   #7 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
this is server problem
Old 03-05-2010, 06:17   #8 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,043
just repair this way.
1. back up certificate, Full PM,
2. Erase whole flash,
3. Full flash with any version after erase.
4. Restore Imei,
5. Repair SD,
6. Load good pm with same phone (use PM-120 and 308 Removal)
7 Activate Super dongle and authorise pm
8. Write pm after pm ok reset the phone , press check , will reset and everything ok,
Old 03-05-2010, 06:18   #9 (permalink)
Member: 1248625
Thanks Meter: 7
klik tab imei&security..klik simlock.... klik restore SIMLOCK backup
klik restore splock
sory brother my english is bad
Old 03-05-2010, 06:22   #10 (permalink)
Member: 752215
Thanks Meter: 21
4. Restore Imei,
5. Repair SD,
already try this solution...but problem still the same....
Old 03-05-2010, 06:23   #11 (permalink)
Member: 752215
Thanks Meter: 21
klik restore splock
restore simlock backup error updating ....
Old 03-05-2010, 06:25   #12 (permalink)
uttam's Avatar
Member: 223135
Sonork: 100.1592685
Thanks Meter: 177
I Reapaired Simlock In 7210c
This Error
SIMLOCK...error 0x1
Old 03-05-2010, 06:40   #13 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
it may be server error as i also faced such problem .......
Old 03-05-2010, 08:52   #14 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
1. backup RPL(just in case).
2. erase EEPROM.
3. Repair SD
4. Full Factory
5. SUPER SD Auth + Write PM1,309
details info
1.Service -> Imei & Security -> IMEI Rebuilt
2.Flash -> advance -> Get address
untick safe erase.
tick eeprom area only
DO "ERASE"
3.repair SUPERDONGLE
4.Full Factory
5."SUPER SD AUTH"
write PM [1] and [309]
br,
The Following 3 Users Say Thank You to Andra For This Useful Post:
Old 03-05-2010, 09:20   #15 (permalink)
Member: 1114795
Thanks Meter: 3
restore simlock backup,
repair sd,
super sd auth/write modified pm
restore simlock backup again..
Thats all...
Just try...
N73 Updating SIMLOCK...error 0x1 (ANSWERED) ..::HITU::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 22 03-11-2012 03:50
5130 Updating SIMLOCK...error 0x1 bhaskarsha Nokia Base Band 5 ( BB-5 ) 23 09-11-2011 19:51
5130 Updating SIMLOCK...error 0x1 (ANSWERED) bhaskarsha MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 04-20-2011 04:50
5220 Updating SIMLOCK...error 0x1[SOLVED] gsmfeng MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 02-09-2010 09:19
Page generated in 0.43454 seconds with 8 queries
