Old 03-05-2010, 07:11   #1 (permalink)
kumar_gsm_kumar's Avatar
Member: 230569
Sonork: 1608865
Thanks Meter: 268
Updating SIMLOCK...error 0x1
UPDATEING SIMLOCK ...ERROR 0X1 5200
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product: V 07.20 23-10-08 RM-174 (c) Nokia.
Using cached productData[18500216430E6B561A3E950271FD82EE282957EB] ...
Calculating SUPERDONGLE using security server ...
Completed in 3.016 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-174_354848019114259_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...
error 0x0
Updating SIMLOCK...OK
Phone Type: RM-174 (Nokia 5200)
SW Version: V 07.20 23-10-08 RM-174 (c) Nokia.
Imei plain: 35484801911425-9
Product Code: 0541045
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354848019114259
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
PLZ HELP
Old 03-05-2010, 07:13   #2 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,045
Server down..check othertool
Old 03-05-2010, 07:30   #3 (permalink)
Member: 895552
Thanks Meter: 31
try again brother.mx key server is back.repair sd.and write pm .and super sd auth good luck brother
Old 03-05-2010, 07:39   #4 (permalink)
Member: 144024
Thanks Meter: 5
server is now ok.i did it now
Old 03-05-2010, 07:45   #5 (permalink)
bashir telecom's Avatar
Member: 541511
Sonork: 1583582
Thanks Meter: 51
server not ok. i am trying form 3hrs
Old 03-05-2010, 07:52   #6 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,429
Originally Posted by kumar_gsm_kumar View Post
updateing simlock ...error 0x1 5200
using device: ufs_usb v2.8 (c) sarassoft 2007.
library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
product: v 07.20 23-10-08 rm-174 (c) nokia.
using cached productdata[18500216430e6b561a3e950271fd82ee282957eb] ...
Calculating superdongle using security server ...
rpl saved to "c:\mobileex\3.3\data\backup\bb5_rm-174_354848019114259_simsd.rpl"
updating superdongle_key ...
error 0x0
updating simlock...ok
phone type: rm-174 (nokia 5200)
sw version: v 07.20 23-10-08 rm-174 (c) nokia.
imei plain: 35484801911425-9
product code: 0541045
language pack:
- not available.
simlock seems to be valid
superdongle_key seems to be valid
simlock_test passed
security_test failed!
imei net: 354848019114259
version: simlock server version 63
counter: 0/3, 0/10
config_data: ffffffffffffffff
profile_bits: ffffffffffffffff
block 1: 1=corrupted
plz help
brother try this.........................
Use repair sl zone then used update simlock option
never to marked make simlock rpl option
post result
Old 03-05-2010, 08:07   #7 (permalink)
Member: 31027
Thanks Meter: 176
server not ok
WHAT IS THAT
Old 03-05-2010, 08:23   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
simple answer
1. backup RPL(just in case).
2. erase EEPROM.
3. Repair SD
4. Full Factory
5. SUPER SD Auth + Write PM1,309
details info
1.Service -> Imei & Security -> IMEI Rebuilt
2.Flash -> advance -> Get address
untick safe erase.
tick eeprom area only
DO "ERASE"
3.repair SUPERDONGLE
4.Full Factory
5."SUPER SD AUTH"
write PM [1] and [309]
br,
Old 03-05-2010, 08:30   #9 (permalink)
Member: 230569
Sonork: 1608865
Thanks Meter: 268
Originally Posted by mobileex-team View Post
simple answer
details info
1.service -> imei & security -> imei rebuilt
2.flash -> advance -> get address
untick safe erase.
do "erase"
3.repair superdongle
4.full factory
5."super sd auth"
write pm [1] and [309]
br,
thanks for quick repply
but other box universal box 100%ok
N73 Updating SIMLOCK...error 0x1 (ANSWERED) ..::HITU::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 22 03-11-2012 03:50
5130 Updating SIMLOCK...error 0x1 bhaskarsha Nokia Base Band 5 ( BB-5 ) 23 09-11-2011 19:51
5130 Updating SIMLOCK...error 0x1 (ANSWERED) bhaskarsha MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 04-20-2011 04:50
5220 Updating SIMLOCK...error 0x1[SOLVED] gsmfeng MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 02-09-2010 09:19
Page generated in 0.31621 seconds with 8 queries
