12-03-2010, 08:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | Updating SIMLOCK...error 0x1 (ANSWERED) i have 2 nokia n73 with phone startup failed , contact retailer... when i try to do "init sim lock" getting the error msg" Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 Completed in 1.125 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-133_355718024688937_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 355718024688937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF " *.i tried before and after super sd *. tried after write PM by super SD auth.... same i am using the version 3.4 revision 1.6 pls help me thanks in advance |
12-03-2010, 09:03 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: IRAN
Member: 1222839 Status: Offline Sonork: 100.1603618 Thanks Meter: 3,944 | Quote:
1-Click Repair simlock 1-click Make Simlock Rpl 2-Use Update Sp Lock Key Br, BEHBOODI | |
12-03-2010, 11:03 | #8 (permalink) |
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | *.first info Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. Imei plain: 35571802468893-7 Product Code: 0563989 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 355718024688937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED *.init simlock result "Imei net: 355718024688937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0812.4.2.1 Using cached productData[1660010D22B802549C5C742F74A06967F7B1B503] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 Completed in 1.157 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-133_355718024688937_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 355718024688937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF " |
12-03-2010, 11:19 | #10 (permalink) | |
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | Quote:
can i ask a doubt ???? is it server (related) problem or my side????? bcos i have already done many time by 1.init sim(by uncheck MAKE SIMLOCK RPL) 2.super sd if security test fail 3.do super sd auth by selecting good pm.... pls help me | |
12-03-2010, 14:17 | #12 (permalink) |
Freak Poster Join Date: Jul 2008 Location: kerala-malappuram-panangangara
Member: 804397 Status: Offline Thanks Meter: 51 | !!! [+] Updating SIMLOCK ... error 0x1 100% SOLUTION !!! !!! [+] Updating SIMLOCK ... error 0x1 100% SOLUTION WITH MXKey First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) [B](If required Recover Cert) |
The Following User Says Thank You to sainu For This Useful Post: |
12-03-2010, 22:43 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
The Following 2 Users Say Thank You to danishalnoor For This Useful Post: |
12-04-2010, 10:24 | #15 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
use rcover cert option in mxkey (its better it can write product code base from server) or write HWW CCC (rpl without NPC) file. | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
