Old 03-09-2012, 17:50   #1 (permalink)
Member: 1342044
Thanks Meter: 51
usb not support reset security code (ANSWERED)
nokia c3 how to reset user code hti flasher new version mobileEx 3.5 (rev1.7) and 8
usb not support reset security code ...............this hti version
any one .....................................solution bro
The Following User Says Thank You to ushe For This Useful Post:
Old 03-09-2012, 18:18   #2 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
flash it after the phone reboot on test mode
The Following User Says Thank You to atou For This Useful Post:
Old 03-09-2012, 20:42   #3 (permalink)
Member: 1342044
Thanks Meter: 51
usb not support " test mode " mobileEx 3.5 (rev1.7) and 8
Old 03-10-2012, 10:40   #4 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
mobileEx 3.5 (rev1.7 use this version and those usb interface
he work very well
Old 03-10-2012, 10:46   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. post buscheck logs & i will give you a solution.
Old 03-11-2012, 02:41   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
flash the phone. less headache.
Old 03-11-2012, 05:31   #7 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
flashing phones not unlock security codes, but it can help u go to local mode and do reset all settings.
in some cases, flashing phones still cant get the phones to local mode, especially in rev 1.7 & 1.8.
@ushe
try flashing in rev 1.5 or 1.6. some of my security codes cases solved with rev 1.5.
or try phoenix crack.
good luck bro
br
The Following 3 Users Say Thank You to specta For This Useful Post:
Old 03-11-2012, 06:12   #8 (permalink)
Member: 1722172
Thanks Meter: 25
please insert the flash file once after that and will appear buschek full service tab - >> action-> reset user code-> reset selected
Old 03-18-2012, 11:37   #9 (permalink)
traxgsm's Avatar
Member: 636518
Thanks Meter: 175
""specta"you 'v 100/100 right ...after flash with rev 1.6 phone is in local mode...
Old 03-18-2012, 12:35   #10 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
good for u bro
or u can just read user code (phone can go to local mode & display all info when buscheck), just in case u failed trying reset all settings (c2-03, x2-02, etc)
br
br
The Following User Says Thank You to specta For This Useful Post:
Old 03-18-2012, 13:10   #11 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 606
bro tery the way 100% working any nokia test mod and local mod ..http://forum.gsmhosting.com/vbb/f717...cable-1425709/
Old 03-19-2012, 07:15   #12 (permalink)
Member: 1540810
Sonork: 100.1627394
Thanks Meter: 161
it easy to read user code but is hard to reset user code with usb without flash
Old 03-19-2012, 08:40   #13 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
@ushe
good luck bro
br
You are 100% right. Today I try to reset security code of Nokia C3 but it does not go to Local Mode by buscheck. Then I flashed it and again it does not go to local mode with version 3.5_rev1.8. Then I searched the forum and found your solution and installed 3.5_rev1.5 and it worked like charm.
The Following User Says Thank You to murtaza_nns For This Useful Post:
Old 03-20-2012, 11:14   #14 (permalink)
Member: 218868
Thanks Meter: 5
same problem
mx team please sort out on latest release. we need to use latest software. not new + old
Old 03-23-2012, 16:26   #15 (permalink)
Member: 303852
Thanks Meter: 32
for me x2-00 reset sec code:
flash with rev 1.5, after flash phone was in test mode
then on hwk ul settings...
next time i will make cable like in this post :
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 04:40
Page generated in 0.19712 seconds with 9 queries
