10-03-2009, 06:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | v3.2 revision 5.2 DCT4 flshing error 7260 Flashing error Using device: J.A.F, FW ver: 01.B1 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0000 0001 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0000 0001 0002 0003 0004 0005 0006 0007 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00113496:2984DA60 ASIC type: 2 UEM Imei: 35060410389287 Flash Imei: 01001635303 Invalid imei checksum ! Processing file: rm17__05.900 as MCU [DCT4,DCT4 ALGORITHM] size: 8.03 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0000 0001 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0000 0001 0002 0003 0004 0005 0006 0007 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00113496:2984DA60 Flash programming ... Error while programming [14] at 0x01000000, Result: 0000 Flashing terminated with error(s) in 1 min 20.453 s RX Buffer: br. |
10-03-2009, 12:07 | #4 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Spinning on my OWN Orbit
Member: 5358 Status: Offline Thanks Meter: 211 | My suggestion is to update the fia files with latest...Performing Flash Authentication ...OK UEM ID: 00113496:2984DA60 Flash programming ... Error while programming [14] at 0x01000000, Result: 0000 Flashing terminated with error(s) in 1 min 20.453 s RX Buffer: check the cable it should be modified... bsi with 10 k resistor. Last edited by eivoig; 10-03-2009 at 12:14. |
10-03-2009, 13:14 | #6 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
it's not the cable also, 100% sure that my cable is GOOD.. revive the phone via UFS with the same cable.. Flash it again on Mx-key older version and went fine with NO errors.. so you see its a bug.. thanks br. | |
v3.2 revision 5.2, Public-Release - PUBLIC DISCUSSION ABOUT UPDATE | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 143 | 10-15-2009 09:34 |
Which DCT4 PLUS ASIC 0x3168 Model & Version are Supported in MX-Key v3.2 revision 5.2 | rajinder1978 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-07-2009 08:35 |
MXKEY v3.2 revision 5.2 not working with Vista Home Basic | srinibas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 10-05-2009 15:33 |
MXKEY DCT4PLUS SP UNLOCK and Imei Changes for ASIC 0x3168 - v3.2 revision 5.2 | MANOLE | Service Products News & Updates | 0 | 10-02-2009 14:13 |
