View Poll Results: Did you know that MXBOX is WORLD FIRST and the ONLY NOKIA BOX with TMA included ? | |||
YES, i know MXBOX is WIRLD FIRST and ONLY one NOKIA box with TMA. | 1,143 | 70.91% | |
No, I didn't know. | 469 | 29.09% | |
Voters: 1612. You may not vote on this poll |
06-25-2011, 12:31 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,944 | v3.5 revision 1.2, Public-Release - MAJOR UPDATE - The only BOX with TMA included MXKEY and MXBOX WORLD SOCIAL NETWORKING BE A PART OF IT MxKey and MXBOX on Facebook MxKey and MXBOX on Twitter MxKey and MXBOX on YouTube v3.5 revision 1.2, Public-Release MAJOR UPDATE What is new: MAIN - Added, Files synchronization feature - Allows to check and update important files with server without installing full setup. - Also useful to minimize problems because of users patch. - Fixed, Access violation on XP for PC without HTI(WinUsb) installed - Check For updates and Single module update removed(replaced with Synchronize Files) NK(Nokia Service Tool) - Added, optional SX5 serial used for SL3 NCK calc (*) (*) required HTI firmware version 00.17 or later - Added, Latest flash update definition to setup - Added, Options to disable/enable RAPIDO new protocol for USB flashing - Added, Options to disable/enable embedded SBL for XGOLD flashing - Added, HTI SoftTMA Resistor selection (*) (*) required HTI firmware version 00.17 or later - Added, Local storage definition for DCC and RFBB data. - Added, DCC data verify after write - Improved, DCC data write (If DCC write fail, DATA will be written as PM) - Fixed, Download in background deadlock bug - Fixed, PM erase bug (was early stopped on newer BB5 phone) - Fixed, DCT4 flashing - Fixed, New ProductProfile write QCD(CDMA Service Tool) - updated patch definition to version 1.4 - added unlock definition for: Haier Q9+-INAV1.04-100326-JWD, method: patch unlock - added unlock definition for: ZTE SM_C36X_RBTL05NV1.0.0B05, method: direct unlock (not tested!) - fixed unlock definition for: ZTE TM_S189_RBTL35NV1.0.2B01, method: direct unlock - fixed unlock definition for: ZTE TM_S168_RBTL35NV1.0.0B02, method: direct unlock - see "modules\{9A05071F-D3A6-484B-8E3E-C6F47311C78C}\supported_phones.txt" for list supported models BB (BlackBerry Tool) - Added, Factory lock status on device scan - Minor bug fixes 420 Links to download MxBox/MxKey v3.5 rev1.2 for FREE 1. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 2. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 3. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 4. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 5. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 6. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 7. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 8. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 9. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 10. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 11. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 12. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 13. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 14. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 15. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 16. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 17. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 18. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 19. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 20. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 21. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 22. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 23. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 24. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 25. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 26. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 27. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 28. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 29. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe 30. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe !!! MXKEY CABLES - LED SERIES !!! 17 pcs SL3 cables in 1 SET, 44 phones supported MXKEY CABLES - LED SERIES - 17 pcs cables in 1 SET, 44 phones supported (WORLD FIRST) - GSM-Forum !!! MXKEY CABLES - LED SERIES !!! 11 pcs SL3 cables in 1 SET, 15 phones supported MXKEY CABLES - LED SERIES - 11 pcs cables in 1 SET, 15 phones supported (WORLD FIRST) - GSM-Forum BR, Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: Manole |
The Following 379 Users Say Thank You to MANOLE For This Useful Post: |
06-25-2011, 12:37 | #2 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Delhi Age: 40
Member: 368590 Status: Offline Sonork: 100.1609194 Thanks Meter: 60 | Lets search for bug anyway nice update including CDMA also |
The Following 5 Users Say Thank You to trinkaljuneja For This Useful Post: |
06-25-2011, 12:53 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 263 | i hope this fix the problem on some old bb5 nokia phones, hard to detect even on bus check only or scan. and the dct4 problem is still in 3.5 rev 1.1 |
06-25-2011, 13:19 | #6 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | Manole sir, box update error how to fix it Using device: HTI FLASHER INTERFACE Interface: HTI BOX (Powered by MXKEY) » BOX FW Version: 00.08 HTI FLASHER INTERFACE ready. HTI firmware outdated, please update your BOX ! NK module ready. Last edited by aashir; 06-25-2011 at 13:24. |
The Following 3 Users Say Thank You to aashir For This Useful Post: |
06-25-2011, 13:38 | #11 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,944 | Again lot of spam posts with tnx. Please read again this forum rules, use tnx button if you need. All spam will be deleted and users will be banned. We are tired to delete all your spam. BR, Manole |
The Following 24 Users Say Thank You to MANOLE For This Useful Post: |
06-25-2011, 13:42 | #12 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | @aashir use latest ver 3.5 revision 1.2 and update your box |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
06-25-2011, 13:55 | #13 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 870664 Status: Offline Sonork: 100.1614707 Thanks Meter: 56 | can we read SH1 with hwk to start bruteforce or not? also please add auto switch off computer after finishing brutforce this can help many people and save energy thnx again! |
06-25-2011, 14:05 | #14 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Please any body can you tell Here this version Perfect / Tested ....................? Mx-box & Ufs Fixed Bug .................? |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
