Old 04-24-2011, 02:57   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
very emaging in nokia n97 [rm-505] (ANSWERED)
phone is come with me only vibretion
i flash latest ver [RM-505_22.0.110_prd.core.C00]
same problem after flash
i make rpl backup other tool and reset npc set is proper on and i backup again simlock
after npc write pfone is come same condition [only vibret]
plz help me expert
here is log
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Processing MCU file: RM-505_22.0.110_prd.core.C00
[BB5,XSR 1.5] size: 106.34 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 15372212
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 08300113C8DA01580C60A67377DF11482F692051
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Flashing CMT Update Server Data, ULO: 0x3B80 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, XSR: 0x29F467 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1AD1E45
Verifying communication to device OK.
Partitioning....
Partitioning complete
Erase size: 167.44 MB
CMT MuxOneNAND area [00040000-00082FFF]
CMT MuxOneNAND area [00083400-003FFFFF]
CMT MuxOneNAND area [00800000-00D5FFFF]
CMT MuxOneNAND area [00D60000-0AB9FFFF]
Formating partition ...
Flash programming ...
CMT PAPUBKEYS: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B (RAP Certificate 166 v.1) written.
Programming completed in 1 min 3.828 s
Processing PPM file: RM-505_22.0.110_prd.rofs2.V24
[BB5,XSR 1.5] size: 15.49 MB
Erase size: 35.00 MB
CMT MuxOneNAND area [079A0000-09C9FFFF]
Programming completed in 9.687 s
Processing PPM file: RM-505_22.0.110.255.03.rofs3.fpsx
[BB5,XSR 1.5] size: 12.01 KB
Erase size: 15.00 MB
CMT MuxOneNAND area [09CA0000-0AB9FFFF]
Programming completed in 0.094 s
Processing CNT file: RM505_APE_ONLY_ENO_09w23_v0.072.fpsx
[BB5,XSR 1.5] size: 2.75 MB
Erase size: 4.00 MB
CMT MuxOneNAND area [00400000-007FFFFF]
Programming completed in 1.750 s
Processing CNT file: RM505_507_22.0.110_uda_2_001.uda.fpsx
[BB5,XSR 1.5] size: 8.79 MB
Erase size: 75.50 MB
CMT MuxOneNAND area [0ABA0000-0F71FFFF]
Programming completed in 5.781 s
Total time for flashing process(boot+erase+write) was 1 min 59.046 s
after reset npc set is proper on but all is bad phone not working
Phone Type: RM-505 (Nokia N97)
SW Version: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0587488
ApeCoreSw: v 22.0.110
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
after write npc set is back same condition
Old 04-24-2011, 04:41   #2 (permalink)
Member: 272979
Sonork: 100.1607215
Thanks Meter: 135
your phone simlock data corrupted if possible repair with rpl backup or buy new rpl
Old 04-24-2011, 06:59   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
plz read care full what i say
i have backup after write backup set is only vibret not proper on
br.
gauravrajput
Old 04-24-2011, 07:07   #4 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
contact me
my yahoo id
Old 04-24-2011, 07:08   #5 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Thanks Meter: 645
Arrow cool bro
maybe it is hardware so see inside
Old 04-24-2011, 07:12   #6 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
before flafing ur set is working ok?%
if ur answer ok...! its sl sata is crupt..
if ur answer is no..! then ur set have hardware prob 100%
Old 04-24-2011, 07:57   #7 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
with npc data set is only vibret
reset npc data set is on where is hardwer bro
Old 04-24-2011, 08:10   #8 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
backup only npc data rpl then rest npc data then under npc data paste other set ccc and hwc data and write on set. ur set ok 100% tested manay times
Old 04-24-2011, 08:29   #9 (permalink)
rk_grover77's Avatar
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
hv u tried to edit rpl????????? if no...edit rpl file and then write new rpl ( edited) and check.
Old 04-24-2011, 08:37   #10 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Hello
flash it with same product code flash file
Old 04-24-2011, 08:48   #11 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
after long time hardwor my set is recover
but my phone come in security test fail
Imei plain: 35422503827028-1
Product Code: 0586577
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354225038270281
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
i write modify pm
sector 1 or 309 but cant ok
now i need n97 without npc data plz uplode
Old 04-24-2011, 08:51   #12 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
bcoz mostly problem here
all data is empty so i need urgenty
TransmissionMode: DDR&TX2
Reading CMT NPC (0x190 bytes)
Original Product Code: 0587488
Reading CMT VARIANT (0x0 bytes)
Reading CMT CCC (0x0 bytes)
CCC empty !
Reading CMT HWC (0x0 bytes)
HWC empty !
Old 04-24-2011, 08:57   #13 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Hello,
Write this rpl and post results
Old 04-24-2011, 08:59   #14 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
N97_without_NPC_DATA__made_by_MxKey.rar
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 04-24-2011, 09:03   #15 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
maney-2 thnx all friends who reply me
my phone is 100000% ok and working
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Page generated in 2.11928 seconds with 10 queries
