Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-06-2012, 20:20   #376 (permalink)
Member: 1056975
Sonork: yahoo
my hti box doesnt flash phone with mbuscable.only work with usb i check it for nxp mulfuncion it is fine.please help.
Old 03-08-2012, 15:00   #377 (permalink)
Member: 962197
I made good use of the option of USD 15 voucher to the box arrived at their destination in perfect condition and super fast with free shipping and full operation of the same so do not hesitate to buy it if your reseller is not responsible for the guarantees.
Greetings from Argentina.
The Following User Says Thank You to elmostro For This Useful Post:
Old 03-08-2012, 19:33   #378 (permalink)
Member: 1342044
mobileEx 3.5 (rev1.6) version dead usb ....... how to Reset User Code and FULL FACTORY
bro............................ solution
Old 03-08-2012, 22:16   #379 (permalink)
Member: 1455412
www.mxlaboratory.com/buy.html
is down
Old 03-08-2012, 22:36   #380 (permalink)
Member: 48396
Flash it with same version or above and then do full factory, this will reset user code too. If you can't flash it via usb, then you have to flash it via fbus.
Old 03-21-2012, 11:57   #381 (permalink)
Member: 879095
Hi,
I have problem with my new hti ORANGE. I can update it, log:
Initializing HTI ...
HTI initialized.
Boot Version: 109
Serial: 01005ABC
Connecting to server: htiupdate2.mx-key.com
Receive data from server ...
Updating HTI firmware v00.50 please WAIT ...
Waiting for HTI in Application mode ...
HTI firmware v00.50 update OK.
But i cant check is it good or NXP chip with malfunction, log:
HTI initialized.
HTI Boot Version: 109
ERROR: Server receive byte failed
ERROR: Receive buff error no: 0x00
ERROR: Function name: HID_UPD_WriteApplication Error number: 04
Can you help me? I cant also use FBUS cable i have error- the cable is 100% ok, its working well with HWK/UFS, JAF and also OLD mxkey,before update.
Error when try BUS check on nokia 5130 (phone is 100%ok)
ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed!
Can you help me, Sir?
Old 04-01-2012, 14:26   #382 (permalink)
Member: 430847
erroer in cnt flash 6230i
hello freinds i need your help in 6230i
when i flash it with mxbox hti flasher interface flashing stop in cnt
mcu ok but the next stop
i synchronise the box
change firmware of 6230i
change cable
but still same problem
there is the log
MXKEY [FT SCR2000 0], SN: 00000000
Using device: HTI, FW ver: 00.50, SN: 00000000
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\35600000321263_BACK.r pl).
Processing MCU file: rm72_73_11003.890
[TIKU BT2,TIKU ALGORITHM] size: 10.14 MB
Supported Ids: 1052, 2051
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 00EF36A5:977ADA60
Area [00000000-0000FFFF] erased in 0.421 s
Area [00010000-009FFFFF] erased in 1 min 3.688 s
Area [00A00000-00B3FFFF] erased in 8.140 s
Area [00B60000-00FAFFFF] erased in 28.078 s
Flash programming ...
Programming completed in 1 min 17.140 s
File processed in 3 min 6.703 s
Processing CNT file: rm72_73_110M_03.89.ucp_G
[TIKU BT2,TIKU MON CSM] size: 3.93 MB
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
Le délai de temporisation de sémaphore a expiré
Error while programming [2E] at 0x01000020, Result: 0000
flashing terminated !
Old 04-02-2012, 02:20   #383 (permalink)
Joey888's Avatar
Member: 815786
Manole,
Do you have other payment option than Paypal or Creditcard?
Old 04-13-2012, 10:29   #384 (permalink)
Member: 9848
Originally Posted by CilianUnlock View Post
Any comment on this from support?
How to redeem voucher?
Old 04-14-2012, 15:36   #385 (permalink)
Member: 984020
Sonork: 100.1626842
Red face i have a problem...can you help me?
Originally Posted by MANOLE View Post
If you want to send back the box, you have to send it to your reseller.
Your reseller is in charge for change your box.
In case your reseller refuse to change your box, then you can use the voucher.
To use the discount voucher you have to go to the link i posted and I explained what for is this voucher:
discount Voucher for use to
order online MXBOX GREEN at 15 USD with free delivery
BUY MXBOX GREEN at 15 USD
WITH Discount VOUCHER and FREE DELIVERY
BR,
Manole
Dear Manole
i have a problem
Your HTI have NXP chip with hardware malfunction
Please use this data to request Discount:
HTI SN:
0000805C
HTI OTP ID: 39F612120D114E53ED8C874B030000F5
Discount VOUCHER: D3F517E5
this link
[url=http://mxlaboratory.com/[/url]
don`t work
I need to acquire the hti with discount, you can say to me like do it? Or to repair the link of the page to acquire it on line?
Thank you
Old 04-14-2012, 23:32   #386 (permalink)
Member: 9848
@Manole @gbluez
Any help, any answer?
Old 04-17-2012, 12:47   #387 (permalink)
tekirdaggsm's Avatar
Member: 106391
cant update
log :
Begin transaction ...
HTI initialized.
 Boot version: 00.07
 Serial: 0000E0FE
Receive firmware from server ...
SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.2
  Firmware version on server: 00.50
  changes:
   added: boot mode switch function
   improved: serial and flash bus communication routine
   added: dct4 product data calc algorithm
   added: broadcom sec.repair algorithm
   minor bug fixed.
Received buff checksum verified OK.
Updating HTI firmware, please WAIT ...
HTI firmware update OK.
» End transaction (status: 0, Successfull)
Waiting HTI in application mode ...Done.
Directory created: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\
Directory created: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\
Updating: changes.txt: OK
Updating: fire.exe: OK
Updating: htic.exe: OK
Updating: mobileEx.lib: OK
Updating: data\drivers\nokia\Nokia_Connectivity_Cable_Driver.msi: OK
Updating: data\drivers\nokia\wp\nokiacareconnectivity.inf: OK
Updating: modules\nk.mx: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\productapiconfiguration.xml: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\sl3u.exe: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLREVA00.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLREVC00.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC01-0542-1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC01-0542-2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC01-0542-8.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC01-0542-9.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC01-0543-1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC11-0542-3.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC11-0542-4.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC11-0542-5.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC11-0542-6.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\ADLTIEC11-0542-7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\BCM21351_PI155_XSR16_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\BCM21351_PI155_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\BCM21351_XSR16_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\BCM21351_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\HERA_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\HERA_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\MICROv10_alg2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\OMAP1510_SAMSUNGSEIJA_7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\OMAP1510_TOSHIBAMDOCG3_7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\OMAP2420_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\OMAP2420_XSR15_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv2_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv2_2nd_fps8.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv30_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv30_XSR14_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv3_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv3_2nd_fps8.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv3_algo.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv3_algo_fps8.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv3_algo_xsr15.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv40_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAP3Gv40_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPIDOv11_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPIDOv11_XSR15_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPIDOv11_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPUv11_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPUv11_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPUv21_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\RAPUv21_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_ED_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_ED_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v11_open_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v11_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v11_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v1_open_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v1_open_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v1_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v1_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v2_open_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v2_open_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v2_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8500_v2_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8815_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\STn8815_STNFMS_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\algerase.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\fpga0313.bin: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\fps8upd.ini: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\fpsxupd.ini: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\fuinst.dll: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_sam_nand_format.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_sam_nand_gbbm.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_sam_nand_hdd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_sam_nand_xsr.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_sam_nand_xsr_small.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\h3_xsr15_flash_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\helen3_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\helen3_2nd_hdd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\i28f640.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\lindabt2.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\loader_TIKUEDGE_INTEL_1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\loader_TIKUEDGE_SAMSUNG_1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\loader_TIKU_INTEL_2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\loader_TIKU_SAMSUNG_2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\m_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\m_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\m_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\mmcu_327.bin: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\nmsw.fps10: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\nmsw.fps20: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\nmsw.fps21: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\omap2420_m1_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\s2_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\s2_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\s3_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\s3_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\t2_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_e_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_essr.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_mucsm.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_oncsm.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\te_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\teflon_sam_nand_xsr151_m1.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\teflon_sam_nand_xsr_m1.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u3_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u3_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u3_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u3_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_st.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\u_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\uh_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\uh_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\uh_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\version.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w2_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\10.48.001.2\w3_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLREVA00.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLREVC00.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC01-0542-1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC01-0542-2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC01-0542-8.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC01-0542-9.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC01-0543-1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC11-0542-3.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC11-0542-4.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC11-0542-5.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC11-0542-6.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\ADLTIEC11-0542-7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\BCM21351_PI155_XSR16_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\BCM21351_PI155_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\BCM21351_XSR16_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\BCM21351_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\HERA_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\HERA_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\MICROv10_alg2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\OMAP1510_SAMSUNGSEIJA_7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\OMAP1510_TOSHIBAMDOCG3_7.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\OMAP2420_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\OMAP2420_XSR15_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv2_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv30_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv30_XSR14_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv3_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv3_algo.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv3_algo_xsr15.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv40_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAP3Gv40_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPIDOv11_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPIDOv11_XSR15_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPIDOv11_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPUv11_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPUv11_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPUv21_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RAPUv21_XSR17_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_B0_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_B0_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_blank_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_blank_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_otp_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_otp_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\RHEA_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v11_open_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v11_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v11_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v22_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v22_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v2_open_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v2_open_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v2_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8500_v2_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8815_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\STn8815_STNFMS_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\XG223_v11_usb2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\XG223_v11_usbalg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\algerase.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\fpsxupd.ini: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_sam_nand_format.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_sam_nand_gbbm.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_sam_nand_hdd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_sam_nand_xsr.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_sam_nand_xsr_small.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\h3_xsr15_flash_alg.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\helen3_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\helen3_2nd_hdd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\i28f640.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\lindabt2.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\loader_TIKUEDGE_INTEL_1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\loader_TIKUEDGE_SAMSUNG_1.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\loader_TIKU_INTEL_2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\loader_TIKU_SAMSUNG_2.adl: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\m_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\m_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\m_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\omap2420_m1_2nd.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\s2_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\s2_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\s3_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\s3_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\t2_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_amd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_amd_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_cbusb.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_e_2nd.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_essr.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_int_b.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_intel.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_mucsm.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_oncsm.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_st_i.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\te_st_ib.fia: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\teflon_sam_nand_xsr151_m1.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\teflon_sam_nand_xsr_m1.fg: OK
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u3_2nd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u3_amd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u3_intel.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u3_st_i.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_2nd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_amd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_amd_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_cbusb.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_int_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_intel.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_st.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\u_st_i.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\uh_amd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\uh_intel.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\uh_st_i.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\version.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_2nd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_amd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_amd_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_cbusb.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_int_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_intel.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_st_i.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w2_st_ib.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_2nd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_amd.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_amd_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_cbusb.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_int_b.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_intel.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_st_i.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.50.000.1\w3_st_ib.fia: CRC FAILED
Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\sl3bf\sl3bf.dat.default: CRC FAILED
Old 04-21-2012, 13:41   #388 (permalink)
Member: 106391
done by myself thx for nothelpng
Old 04-28-2012, 18:07   #389 (permalink)
Member: 101683
need help
my box when i choce nokia interface i get this error only whis hti on usb it work
what can i do for this ???
i make update to hti but the same error
Old 04-30-2012, 06:57   #390 (permalink)
Member: 78497
Sonork: 100.1602700
hello,
What you wrote IPmart:
Dear Mr. Arunas
we have shipped back many boxes to him and no sound from author. Best you ask author for address to ship directly back to him since he waste our time and trick all our customers by saying he will replace us, but until now, no replacement from him.
Ask him if he is a responsible author, why not all end users just ship back to him directly and stop wasting reseller time and money.
And ask him how come ipmart sent him boxes in passed 2 to 3 months and no sound from him only empty promises.
what can I do to change it HTi box???
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 08-03-1999 15:29
need reference about spterminator&andreww bennet king76 The Market Feed Back 3 08-03-1999 15:25
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-06-1999 23:47
Page generated in 0.59108 seconds with 12 queries
