10-05-2009, 16:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | WARNING DON'T try 1661 FOR UNLock dont try to unlock 1661 rh-122 with MX-KEY, iit will kill your mobile info here locked to t-mobile Imei net: 01188500047946 Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 than i try to unlock with MX-KEY new update 3.2 rev 5.2 PhoneType:RH-122 SwVersion: V 04.30 06-07-09 RH-122 (c) Nokia MCU file: rh122_004.300 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056C643A3BDA66 Area [01000000-0101FFFF] erased in 1.578 s Area [01160000-0117FFFF] erased in 1.594 s Programming ... Programming completed. Phone not responding ! after that phone dead then flash phone with MX-KEY and take info Phone Type: RH-122 SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: ??????????????-? Product Code: 0579235 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. TimeStamp: 2009-02-12T04:54:29Z SW Version: 03.10 Variant Version: 001 ProductProfile: RH122_0579235_03.10_001.spr Simlock: 0579235_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! imei became ?????????????-4 try to write rpl file ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056C643A3BDA66 Programming FLASH Imei ...failed warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RH-122 SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: ??????????????-? Product Code: 0579235 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. TimeStamp: 2009-02-12T04:54:29Z SW Version: 03.10 Variant Version: 001 ProductProfile: RH122_0579235_03.10_001.spr Simlock: 0579235_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! phone has damaged imei now... any solution from solution????????????????????? |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
10-05-2009, 16:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | when you install mxkey setup there is a text file about supported models in c:\mobileEx\3.2. plz read that before try. |
The Following User Says Thank You to Imran Bhatti For This Useful Post: |
10-05-2009, 16:07 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | that phone is not supported yet,. i thinks lots member give that info to br, |
The Following User Says Thank You to Andra For This Useful Post: |
10-05-2009, 16:19 | #4 (permalink) |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | 1661 not support on any device dont try it now write back up if u have look in C:\mobileEx\3.2\data\backup and try otherwise u need good rpl |
10-05-2009, 21:39 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | I think we have to give full specification which Dct4 plus model is supported with the new update. Br. Vijendra Saini. |
**warning** don't try to unlock bb5 phones from telcel mexico | infogsm | BB5 Box by D.K. | 9 | 04-12-2009 16:43 |
don't try to unlock 1112 or 1110 with v6.46 | bilm25 | HWK | 0 | 12-08-2007 23:35 |
don't try unlock z200 whit new file on server | hrco | Cruiser Suite | 9 | 02-21-2004 18:22 |
Warning!!!! don't use new soft for be5 by orbital gsm | gsmspace | Alcatel & TCL Old Models | 6 | 06-02-2001 12:34 |
