Old 05-07-2010, 17:38   #1 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 230
Warnning downgrade N96-1 Rm-247 or flash it with last version (answered)
Before doing any procedjure with N96-1 , first backup imi: all section by jaf ,mt
hwk or whatever but the best tool to do that is Mxkey
Second if u have not mxkey do it at ur own risk coz update and downgrade
for example in jaf or hwk make sp data corrupted after downgrade and
the result is contact service .Then u will be in a problem coz u havent Mxkey
it is the only tool to solve it ,otherwise dont update it ,it create another problem ,blinks white screen and switch off immediately after update
Third we can use the last verion in case of it is completely dead and it works but still blink white and switch off immediately , make info ,it shows detail ,downgrade it to lower version e.g RM-247_11.018_010.1_ and then of course,contact service. Mxkey only will solve it and no need to buy Rpl
Hope to be useful 4 u
Say thanks if it is useful
The Following 2 Users Say Thank You to tariq_h For This Useful Post:
Old 05-07-2010, 19:49   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
In my experienced, downgrade never caused contact service, it makes the phone death or it will switch on, but just blink or Nokia logo comes and then hang or switch off. Also you cannot enter into another mode, i.e local mode, test mode .. etc.
Also you said,
Not true Bro, update will never ever make sp data corrupted, where did you get these info?? Sorry bro, but i have to say this, Please read before you post, the information you've given here are all wrong.
Old 05-07-2010, 20:04   #3 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 230
Also you said,
it is very true ,let other members try and see the reaction
Old 05-08-2010, 09:16   #4 (permalink)
babloojaved's Avatar
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
we cant flash N96 with mx key,
i tried in usb it will gives this error
and with HWK as interface it will gives this error
and with jaf Error sync the phone
and in HWK flash and uisettings 100% but white display & blank display phones is nearly dead.
and flashed with ENO file in HWK, and then flashed with original one gives this error
data_blk_error at: 0x02610800, 00
err: Ape flash write d_blk 000000000000000910000000b172, ln: 0x008000, time: 03:13
process failed, repowering mobile
from all that i finally flashed with Phoenix dead usb my phone is alive 100%
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
--- Press phone's power button! ---
Unable to open and parse ApeUlo file C:\Programmi\File comuni\Nokia\Tss\Flash\MICROv10_alg2nd.fg
Loading secondary boot code: 39104 bytes
Secondary boot loaded
Loading update server code: 406657 bytes
Update server loaded
Unable to open and parse CmtUlo file C:\Programmi\File comuni\Nokia\Tss\Flash\MICROv10_alg2nd.fg
Loading slave secondary boot code: 15168 bytes
Slave secondary boot code loaded
Loading slave update server code: 461320 bytes
Slave update server loaded
Partitioning....
Partitioning complete
Erasing....
Erasing complete
Asic CMT: Start programming 6301 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic APE: Start programming 129288 KB...
Asic APE: Programming data sent: 0%
Asic APE: Programming data sent: 10%
Asic APE: Programming data sent: 20%
Asic APE: Programming data sent: 30%
Asic APE: Programming data sent: 40%
Asic APE: Programming data sent: 50%
Asic APE: Programming data sent: 60%
Asic APE: Programming data sent: 70%
Asic APE: Programming data sent: 80%
Asic APE: Programming data sent: 90%
Asic APE: Programming data sent: 100%
Programming complete
Asic CMT: programming succeeded
Asic APE: programming succeeded
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
USB Flashing succeeded.
Phone flashing completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Product code changed
Started product mode change
Product mode change complete
Doing factorysets
Factorysets complete
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: mode change post delay
Sub-procedure completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Starting to backup/restore data item: ProductProfile, version: 1.1
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
Starting backup/restore sub-procedure: Mode change
Mode change
Mode change
Backup/restore result: 0 out of 1 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
All operations completed
Product flashing succeeded.
now my phone is 100% ok
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: 1F1687DBC5BA6E4C65C91730F5EF913E3C105DBD
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 21700102DD6B0052D8099FFF8F184CC95EF04A14
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE
ALG [35]: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: 35486302277995
Original Product code: 0572321
Bluetooth ID: 0022FCB4ECAF
WLAN ID: 0022FCB5D70F
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 3548630227xxxx-x
Product Code: 0572321
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3548630227xxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
thanks
The Following 4 Users Say Thank You to babloojaved For This Useful Post:
Old 05-09-2010, 19:57   #5 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
thanks
Bro, how to use phoenix? Do we need any additional hardware to use phoenix? Or is it possible to use by only Authorized Nokia Service Center?
Old 05-10-2010, 07:38   #6 (permalink)
Member: 1268421
Thanks Meter: 4
I also facing the same problem at the moment.......
I flashed with V30.033 , after that..... when i ON the phone white screen then go 2 Off..... To solve this problem, what can i do, pls help 2 me. Urgent.................Pls!
Old 05-10-2010, 09:37   #7 (permalink)
Member: 1268421
Thanks Meter: 4
erasing...............
then..... error come,
How can i continue.............?
Old 11-01-2010, 19:18   #8 (permalink)
Member: 1432680
thanks
just a short question, can I use with '' normal NOKIA N96 USB CABLE? ''
I want to fix it at home. It is possible?
I've tried it with Phoenix, but PHOENİX says '' NO PRODUCT '' :-(((((((((((((((((((
Old 11-02-2010, 23:13   #9 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,948
This is MXKEY section.
Try with MXKEY.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 14:12
Page generated in 0.44551 seconds with 8 queries
