WD timer enabled, phone will reboot itself after 3 min. Phone is nokia e63 how to fix it ? |
brother many times discuss this issue just go to imei option repair sd and then write modified pm with supersd your problem will be solved |
use this guide (bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik now selact>> pm lord from file>>pm auth>> write pm now your fone is ok insha**************** |
I think not possible its sl3........I could be wrong but i think |
when i done this this happens SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! then i make repair simlock with make simlock rpl checked and everything starts all over again |
do the red step and write the info log here ... |
Bro Quote:
must visit.. here u can find all solution by mx-key with pic help :) http://forum.gsmhosting.com/vbb/show...35#post5383535 http://i46.tinypic.com/14v62hh.gif (¨`·.·´¨) `·.¸(¨`·.·´¨) Keep (¨`·.·´¨)¸.·´ Smiling! `·.¸.·´ Gsm_3GN |
i press write and it says "you are about to rewrite simlock settings you want to skip?" i press NO Quote:
SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! |
when i make super sd auth and press yes to "you are about to rewrite simlock settings you want to skip" i get this, SECURITY_TEST failed! if i press no to "you are about to rewrite simlock settings you want to skip" i get this SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! so how to fix security test failed or can i leave it that way or it must be fixed ? |
1:Connect ur mobile and press scan botton. 2:Click on SERVICES. 3:Goto IMEI & SECURITY tab. 4:Click on SIMLOCK in left hand. 5:Put a tick mark in Make SIMLOCK RPL 6:and click Update SpLock Super SD Auth, then write PM1 and PM309 regarding connected phone model |
i have only one file .pm when i load it i have two choices 120 and 308 and shall i put tick mark on pa_sl2 when i do Update SpLock ? |
dont write this pm press scan and post full logs here |
download this pm .......http://rapidshare.com/files/35982553...37_rpl.pm.html Super SD Auth, then write PM1 and PM309 regarding connected phone model |
