Old 03-06-2010, 15:41   #1 (permalink)
Member: 1146326
Thanks Meter: 12
WD timer enabled, phone will reboot itself after 3 min.
Phone is nokia e63
how to fix it ?
Old 03-06-2010, 15:45   #2 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
brother many times discuss this issue
just go to imei option repair sd and then write modified pm with supersd
your problem will be solved
Old 03-06-2010, 15:45   #3 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 810
Originally Posted by frozone View Post
Phone is nokia e63
how to fix it ?
use this guide
(bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>>
repair sd ) now go to pm section only super sd auth betan clik
now selact>> pm lord from file>>pm auth>> write pm
now your fone is ok insha****************
Old 03-06-2010, 16:05   #4 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 451
I think not possible its sl3........I could be wrong but i think
Old 03-06-2010, 16:32   #5 (permalink)
Member: 1146326
Thanks Meter: 12
when i done this this happens
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
then i make repair simlock with make simlock rpl checked and everything starts all over again
Old 03-06-2010, 16:40   #6 (permalink)
Member: 1048527
Sonork: 100.1591570
Thanks Meter: 4
do the red step and write the info log here ...
Old 03-06-2010, 16:53   #7 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
Cool Bro
Phone is nokia e63
how to fix it ?
Bro 1st need log
must visit..
here u can find all solution by mx-key with pic help
http://forum.gsmhosting.com/vbb/show...35#post5383535
`.(`.) Keep
(`.). Smiling!
`.. Gsm_3GN
Old 03-06-2010, 17:00   #8 (permalink)
Member: 1146326
Thanks Meter: 12
Using cached productData[13E00005187A0052CAEBB1DC0AED7182ACC91C1A] ...
Calculating SUPERDONGLE using security server ...
Completed in 1.382 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-437_3568360229*****_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Updating SIMLOCK...OK
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
i press write and it says "you are about to rewrite simlock settings you want to skip?" i press NO
Writing PM from Node ...
Section: 120
- Key: 0, size 56 bytes written.
Section: 308
- Key: 1, size 8192 bytes written.
Completed in 6.820 s
Old 03-06-2010, 17:08   #9 (permalink)
Member: 1146326
Thanks Meter: 12
Originally Posted by gsm_3gn View Post
Bro 1st need log
must visit..
`.(`.) Keep
(`.). Smiling!
`.. Gsm_3GN
i done exactly the same thing but then i get this... and everything starts all over again (
SIMLOCK invalid!
Old 03-06-2010, 17:43   #10 (permalink)
Member: 1146326
Thanks Meter: 12
when i make super sd auth and press yes to "you are about to rewrite simlock settings you want to skip"
i get this,
if i press no to "you are about to rewrite simlock settings you want to skip"
i get this
SIMLOCK invalid!
so how to fix security test failed or can i leave it that way or it must be fixed ?
Old 03-06-2010, 17:45   #11 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
i get this,
i get this
SIMLOCK invalid!
1:Connect ur mobile and press scan botton.
2:Click on SERVICES.
3:Goto IMEI & SECURITY tab.
4:Click on SIMLOCK in left hand.
5:Put a tick mark in Make SIMLOCK RPL
6:and click Update SpLock
Super SD Auth, then write PM1 and PM309 regarding connected phone model
Old 03-06-2010, 18:01   #12 (permalink)
Member: 1146326
Thanks Meter: 12
i have only one file .pm when i load it i have two choices 120 and 308
and shall i put tick mark on pa_sl2 when i do Update SpLock ?
Old 03-06-2010, 18:05   #13 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
dont write this pm press scan and post full logs here
Old 03-06-2010, 18:09   #14 (permalink)
Member: 1146326
Thanks Meter: 12
Phone Type: RM-437 (Nokia E63)
SW Version: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia
Imei plain: 356***
Product Code: 0582456
ApeCoreSw: 100.21.110
ApeVariant: 100.21.110, ApeTest: RM437ENO8745718441.011
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 356***
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
this is before i write the pm file, if i write it
SIMLOCK invalid!
Old 03-06-2010, 18:15   #15 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
download this pm .......http://rapidshare.com/files/35982553...37_rpl.pm.html
WD timer enabled, phone will reboot itself after 3 min. ## (ANSWERED) .::PATEL TELECOM::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 43 10-02-2011 17:46
Nokia 3110c WD timer enabled, phone will reboot itself after 3 min jodhpur_raj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-30-2010 22:59
WD timer enabled, phone will reboot itself after 3 min misterG MXKEY Nokia Flasher and Unlocker (by Alim Hape) 12 01-14-2010 03:20
WD timer enabled, phone will reboot itself after 3 min. ehsas_ghum MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-16-2009 12:11
WD timer enabled, phone will reboot itself after 3 min gul_hassan528 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 09-14-2009 23:18
Page generated in 0.43372 seconds with 8 queries
