12-24-2010, 20:19 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | GPU: Graphic Process Unit.(CPU located on graphics cards) Bruteforce: a brute force exhaustive unlock key search is a strategy that can be used against any encrypted data.... professional solution for recovering Unlock key from hashes using the exhaustive search and utilizing the power of GPU. . Last edited by MOURAD™; 12-24-2010 at 20:27. |
The Following 8 Users Say Thank You to MOURAD™ For This Useful Post: |
12-24-2010, 20:30 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | then why we need active mx key ........? |
12-24-2010, 20:31 | #7 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
12-24-2010, 21:50 | #9 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Brasil
Member: 694980 Status: Offline Thanks Meter: 91 | This is Bruteforce (also known as brute force cracking) is a method of trial and error used by application programs to decode encrypted data such as passwords or (DES) Data Encryption Standard keys, through exhaustive effort (using brute force) in Rather than employing intellectual strategies. Just as a criminal can get in, or "crack" a safe, trying various combinations, a brute force cracking application proceeds through all possible combinations of characters in a string of law. Brute force is considered infallible, although time-consuming approach. Teams MT, UB and others use this method. on your server. super pitted do in a short time and return with the correct codes. Mr. Manole just put this in your secret MXKEY had used your processor and video card to do all the work. and if you have a weak pc it will take several years making attempts to hit you release the right code |
12-25-2010, 09:06 | #10 (permalink) |
Freak Poster Join Date: May 2010 Location: HOLLYWOOD
Member: 1312925 Status: Offline Thanks Meter: 49 | but Why Mxkey Not install this high configuration System there own Server.why ask ppl for buy this? i dont much understand about brute force code calculation. i have to say only if mxkey team arrange high configuration pc/Hardware equepnents in there server for calculation code that will be better. |
12-25-2010, 11:16 | #11 (permalink) | |
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | Quote:
The Following 2 Users Say Thank You to MOURAD™ For This Useful Post: |
12-25-2010, 11:53 | #12 (permalink) |
Freak Poster Join Date: May 2008
Member: 764516 Status: Offline Thanks Meter: 55 | A GPU (Graphics Processing Unit) is a processor attached to a graphics card dedicated to calculating floating point operations. A graphics accelerator incorporates custom microchips which contain special mathematical operations commonly used in graphics rendering. The efficiency of the microchips therefore determines the effectiveness of the graphics accelerator. They are mainly used for playing 3D games or high-end 3D rendering. A GPU implements a number of graphics primitive operations in a way that makes running them much faster than drawing directly to the screen with the host CPU. The most common operations for early 2D computer graphics include the BitBLT operation, combining several bitmap patterns using a RasterOp, usually in special hardware called a "blitter", and operations for drawing rectangles, triangles, circles, and arcs. Modern GPUs also have support for 3D computer graphics, and typically include digital video–related functions thats why this is most necessary to process the codes |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
