Old 09-11-2011, 08:41   #1 (permalink)
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,488
what is this error..??????
i have nokia 1616 dead phone.....
i flashed it but show this error....
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 0] - C0808E49
Using device: HTI BOX, FW ver: 00.17
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rh125_003.610
Downloading item CODE:hw_f11_rh125_r03.610.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 49.399 s
Erasing area 0x00C60000-0x00E5A5FE ...OK
Programming completed in 45.414 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.162 s
Checksum mismatch: Phone calculated 0xA1F3, software calculated 0x9BE4
Processing file: rh125_003.61ej
Downloading item CUST:hw_f11_rh125_003.61ej.fls, num block: 1, size: 2.01 MB
Erasing area 0x00210000-0x00411EFE ...OK
Programming completed in 46.383 s
Checksum mismatch: Phone calculated 0x7DB8, software calculated 0x63CF
Processing file: rh1250_nai03.61ej
Downloading item CUST:hw_f11_rh1250_nai03.61ej.fls, num block: 1, size: 320.14 KB
Erasing area 0x00EB0000-0x00EFF37E ...OK
Programming completed in 7.229 s
Checksum verified (0x4BE7)
Total time for flashing process(boot+erase+write) was 3 min 55.70
what is solution....????
is it software or hardware fault...????
mobi_soft
Old 09-11-2011, 10:35   #2 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
THis is hardware problem!!
CPU problem try to reball and check connections!
Br,
Axecom
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.11804 seconds with 9 queries
