03-23-2010, 07:01 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | (WHAT A NICE TOOL)N5130c contact service... Quote: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed SECURITY_TEST passed action taken write back up rpl Quote: Imei: 35XXXXXXXXXXX Updating PRODUCTCODE (0571943)... OK Updating PSN (HEC950583)... OK Updating HWID (1000)... OK Updating SIMLOCK...OK Updating WMDRM_PD...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1CE00110CD8D7D56FBB1FC4507FDC250E4F0158C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 353XXXXXXXXXXXX Product Code: 0571943 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35XXXXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF next repair sd Quote: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 07.95 03-02-10 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 7.938 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_353223039290342_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 after repair sd security_test failed occur so i tick super sd authentication (write pm 1-309 only) Quote: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 07.95 03-02-10 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 1, size 70 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 5, size 276 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 9, size 384 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 13, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. - Key: 20, size 32 bytes written. - 120 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 21.094 s write also pm field 120 and 308 via super sd auth. (failed on 308) Quote: Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... - 120 skipped - 308 skipped Completed in 7.265 s Writing PM from Node ... Section: 120 - Key: 0, size 944 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 130 bytes written. Section: 308 Warning: failed to write 308 - 1 (8192 bytes) Completed in 3.781 s Done!!! nfo again Quote: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 3XXXXXXXXXX Product Code: 0571943 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35XXXXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF egnore simlock invalid... it's mxkey bug analyze security w/ cyclone it passed Quote: Started Phone Security Analysis... MCU Version V 07.95 MCU Date 03-02-10 Product RM-495 Manufacturer (c) Nokia IMEI 353223039290342 Mastercode 2562313452 Reading Security Block... Security block OK and saved to "RM-495_353223XXXXXXXX_3142010_125543 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "1CE00110CD8D7D56FBB1FC4507FDC250E4F0158C.C000 003D " Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CE00110CD8D7D56FBB1FC4507FDC250E4F0158C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F jaf info Powering the phone... Reading... MCU SW version: V 07.95 03-02-10 RM-495 (c) Nokia HW version: 1000 PCI version: RFIC version: 06540601 DSP version: ICPR72_10w01 LCD version: SEIKO PPM version: V 07.95 03-02-10 RM-495 (c) Nokia EL BT MCM version: 2222-302 Retu version: 16 Tahvo version: 22 Content Pack version: Content: el_blu V 07.95 03-02-10 RM-495 (c) Nokia Production serial number: HEC950583 Product code: 0571943 Module code: 0204024 Basic production code: 0567772 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 35XXXXXXXXXXXXX IMEI spare to net: 3A 35 22 03 93 92 30 04 IMEI SV to net: 33 35 22 03 93 92 30 44 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN finish product/all working (signal, music player etc.) Last edited by akhil_bbsr; 03-23-2010 at 07:07. |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
03-23-2010, 07:17 | #5 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | gnore simlock invalid... it's mxkey bug SOME TIME EVEN SIM LOCK VALID IT SHOWS ,WE THINK ITS DAMAGED, I THOUGHT AS U THINK,BUT NOT DAMAGE, CHECK IN OTHER TOOL,NOW U CAN SEE FULL LOG... analyze security w/ cyclone it passed Quote: Started Phone Security Analysis... MCU Version V 07.95 MCU Date 03-02-10 Product RM-495 Manufacturer (c) Nokia IMEI 353223039290342 Mastercode 2562313452 Reading Security Block... Security block OK and saved to "RM-495_353223XXXXXXXX_3142010_125543 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! |
03-23-2010, 09:35 | #11 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | you mean u use mxkey , then u check ur work with jaf nd cyclone , right? so ur steps is: 1-write backup rpl ( which result SIMLOCK_TEST passed) 2-repair sd Quote:
4- write also pm field 120 and 308 via super sd auth. (failed on 308) 5 - then simply power on ur phone nd , is this the steps u followed?? i will test that !!! then i will post log here | |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
nokia 6303c contact service help.............. | RABIULSK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-09-2010 21:18 |
nokia 6303c contact service help...... | RABIULSK | Universalbox | 5 | 03-30-2010 11:31 |
what good hwk repair contact service??? | cindown | HWK | 0 | 09-10-2009 08:20 |
i have a contact service 5110 v5.28 phone, what should i use to download the eeprom, | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-16-2000 16:20 |
