12-27-2012, 12:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 41
Member: 162611 Status: Offline Thanks Meter: 315 | %% What is the pb nokia 300%% MXKEY [FT SCR2000 0], SN: C08450C3 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00008B1A Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14213(16-10-2012) Processing MCU file: rm781__07.65.mcusw [BB5,XSR 1.6] size: 28.66 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 461E0000FFFB3C404DE404A63FC59AD3B2182255 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 166BAF9F FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 44.56 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-012BFFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [02D00000-032FFFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [012C0000-020FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT PRIMAPP block sent CMT KEYS block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 9C9241FD [] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 5.985 s Processing PPM file: rm781__07.65.ppm_c [BB5,XSR 1.6] size: 7.88 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 12 MB CMT FLASH,MuxOneNAND area [02100000-02CFFFFF] Flash programming ... Programming completed in 1.578 s Processing CNT file: rm781__07.65.image_c_059J7F9 [BB5,XSR 1.6] size: 44.62 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 189.56 MB CMT FLASH,MuxOneNAND area [03300000-0F07FFFF] Formating partition ... Flash programming ... Programming completed in 7.031 s Total time for flashing process(boot+erase+write) was 25.406 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 166BAF9F Waiting for USB device removal ...OK Waiting for USB device arrival ... Warning: Phone did not reboot to normal mode. |
12-27-2012, 14:25 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, You have Flashed Phone with Mismatch Version to change Language, Download & Flash it with Latest Firmware of your Phone Product Code, If same then check whether you Backup RPL, Simlock & PM, Try to Erase from this steps: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Flash it Latest Firmware will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-27-2012, 20:07 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | & Flash With Same Product Code. BR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
12-28-2012, 17:11 | #4 (permalink) | |
Member: 162611 Status: Offline Thanks Meter: 315 | Quote:
Please i dont have the flash file for my product code my product code is: 0568362 give me please the flash file for this product code | |
12-28-2012, 17:25 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | any product code doesn't matter. result on any mismatched product code won't bring any bad. 1. Update your mobileEx FIRST, you are still using an older version. http://forum.gsmhosting.com/vbb/f550...hread-1584847/ 2. Redownload your phone firmware - suspect it is corrupted. Repeat flashing. 3. Will talk later after you did all above instructions. |
