06-12-2013, 18:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | What the problem with this log EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: AA540000FFFB3C40BEE1E4DAD8E9040EC437DB53 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 10.48.1 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 10.48.1 revision: 3.0 size: 0xC965C Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Processing MCU file: rm775__07.58.mcusw [BB5,XSR 1.6] size: 30.55 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Storing certificate [NPC, CCC, HWC, R&D] ...Error Erase size: 44.56 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-012BFFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [02D00000-032FFFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [012C0000-020FFFFF] Formating partition ... Prog.status for Asic CMT ... Flash programming ... Error while programming [00] at 0x00000000, Result: 0000 Tanks |
06-13-2013, 11:15 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Please check, if Full PM or any Backup present for this Phone in your PC, which i don't think so, If present, then you're LUCKY & do Erase with following steps here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Flash it with the Original Firmware & Restore Backup, If no Backup, then also follow above steps will make Phone Alive, But have to Buy Factory RPL to resolve it. BR, ZUBER |
06-13-2013, 13:09 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Yes Bro. You can use RJ45 for all Operations & Flash it with FBus Cable, Pinout for Fbus is here: Post reply with necessary Logs or Screen Shot, if problem persist. BR, ZUBER |
