Why any body not answering my question Here on this forum every member suggests for buying credits to repair SUPER SD Auth. and PPM Auth. I bought 200 credits 100 for DCT4+ and 100 for BB5 Now when i check support area i get 150 credits for DCT4+ and 133 credits for BB5 I have made almost 200 attempts to reapir SUPER SD and PPM for 1 & 309 field PM .. but Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 06.51 23-03-09 RM-436 (c) Nokia Imei plain: 35196********* Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! to reapair this through SUPER SD Auth. I get this error Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06.51 23-03-09 RM-436 (c) Nokia Using cached productData[04A001165FA87D567C6230F93014918E1307C811] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request to reapair this through PPM Auth. I get this error Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(CN), hello 117.254.40.91 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Now Please advise me what to do. |
sever is down bro pls try after some time........ or check ur internet connection |
Code: SECURITY_TEST failed! Code: Bad phones ack, probably SUPERDONGLE_KEY corrupted ! |
my internet connection is ok .. and how long the server will be bussy .. customers do not understand it |
that is strange i already know the way to repair .. but the server is responding with error and how we select another server please more details |
i try with diffrent server but still problem is same http://forum.gsmhosting.com/vbb/f550...rupted-997372/ |
how to select server is here; choose the one that have good connection... http://img32.imageshack.us/img32/1091/serverlisti.jpg |
which version u ll use?? |
Previous version can't do transactions based server. Use newest version.... |
Try to write PM 1 & 309 without "Super SD Auth", of course you get error in writing but let it finish then do "Super SD Auth". I've tried that before with 7210s also and it works. |
now server is working very good try again./ |
still same error Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
brother Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (12 bytes) Warning: failed to write 1 - 2 (70 bytes) Warning: failed to write 1 - 3 (70 bytes) Warning: failed to write 1 - 4 (70 bytes) Warning: failed to write 1 - 6 (276 bytes) Warning: failed to write 1 - 7 (256 bytes) Warning: failed to write 1 - 10 (384 bytes) Warning: failed to write 1 - 11 (384 bytes) Warning: failed to write 1 - 14 (384 bytes) Warning: failed to write 1 - 17 (32 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 0.812 s |
