05-29-2009, 01:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | Why can't write PM in BB5? check here 1. w/ damaged rpl data u cant use sx4, tested. ds will b d result No SX4 Card found. Connecting to server ...MXKEY-SERVER v2.3 hello 122.164.14.231 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! (this is not server problem) if u got rpl back-up, just erase npc then write pm w/out using sx4. just write back rpl back-up afterward if u dont have rpl back-up then buy logs for rpl 2. simlock data not damaged but since there is protection in rpl data and whatever that is why you can't write pm that easy. make rpl full back-up (also full pm back-up for safety purposes), erase npc, now write pm, then write your full back-up rpl. now that should easy. which means in some models probably, with the presence of rpl data, this restrict to write PM, that is why we do erase npc 1st this procedure is in fact useful in troubleshooting CS in several BB5 phones. before unlocking notorious BB5 models make sure to make full PM back-up and full RPL back-up. Last edited by Rabatu; 05-29-2009 at 01:28. |
05-29-2009, 14:38 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Location: ((EGYPT)) walid badr Age: 44
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | Quote:
BUT IF PHONE WORKED WELL AND CAN'T MAKE SX4 TO IT SELFTEST ALL OK MORE THEN 10 PHONE'S SAME PROPLEM LOOK AT HERE | |
05-30-2009, 07:15 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | same problem here too... Scanning local SX4 Card ... No SX4 Card found. Connecting to server ...Connecting to server ...Connecting to server ...MXKEY-SERVER v2.3 hello 117.206.48.150 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! here the case is of a working phone it was a sl zone repaired set now it turns off with in 10 minute till 10 minute the fone works fine and when trying to log on Connecting to server ...OK, Login ... Connection timed out(1)?ß |
Write pm in bb5 without sx4 | alamgarh | Nokia Base Band 5 ( BB-5 ) | 2 | 02-10-2009 06:43 |
Why cant Write Pm on N70 | yousaf22us | Nokia Base Band 5 ( BB-5 ) | 1 | 05-23-2007 09:15 |
can't write PM !!! | the_laser | Board, Server and Login Problems/Support | 3 | 01-28-2004 07:55 |
Why Can't write 6210??? | Schwieger-Sohn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-09-2001 15:05 |
