Old 06-07-2011, 07:52   #1 (permalink)
Member: 1006214
Thanks Meter: 12
WHY I CAN'T CALCULATE RPL DCT4???please help gbluez (SERVER OK NOW)
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 007D3E7B:3B8ADA60
ASIC type: 6
UEM Imei: 03713133918
[InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03)
but with bb5 ok to connect at server ??
Old 06-07-2011, 08:09   #2 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
wait server is down for maintenance .................
try to change server
or
write here imei number i can give you dct4 rpl............ free
Old 06-07-2011, 09:01   #3 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
this is with server 4
Reading ASK DATA ...
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 005FF33A:2984DA60
ASIC type: 2
UEM Imei: Empty
Old 06-07-2011, 09:01   #4 (permalink)
Member: 392149
Thanks Meter: 199
Bro i think server was down but now server is ok and dct4 rpl calculated
bro try to change server in server list and try again
BR,
Old 06-07-2011, 09:06   #5 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
Reading ASK DATA ... this is with server 1
ASIC type: 2
UEM Imei: Empty
Old 06-07-2011, 13:17   #6 (permalink)
mr_loverman's Avatar
Member: 87722
Thanks Meter: 112
352287015724120 asic 6 rpl need please
Old 06-07-2011, 13:22   #7 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
http://dl.dropbox.com/u/12856180/352287015724120.rpl
here is your rpl
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
Old 06-08-2011, 07:05   #8 (permalink)
Member: 1006214
Thanks Meter: 12
Originally Posted by Reet_20_07 View Post
i need rpl with product data for 6275???can you make for me?? thanks,
Old 06-08-2011, 07:35   #9 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
ok give me imei no and asic id ..............(onley dct4 ++ rpl is free)
Old 06-08-2011, 07:43   #10 (permalink)
MR KHATRI's Avatar
Member: 922365
Thanks Meter: 32
Sir plz i need a rpl 354311047774206 asic 11
Old 06-08-2011, 07:50   #11 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
here your rpl file
http://dl.dropbox.com/u/12856180/354311047774206.rpl
Old 06-08-2011, 09:54   #12 (permalink)
MR KHATRI's Avatar
Member: 922365
Thanks Meter: 32
thanksss for rpl file but sir how to write imei for nokia 1280
Old 06-08-2011, 10:19   #13 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
go to imei tab and press write rpl and select rpl file
Old 06-08-2011, 15:49   #14 (permalink)
Member: 560349
Thanks Meter: 5
please help server is down
UEM ID: 009637B6:2984DA60
ASIC type: 2
UEM Imei: 35484001704487
Flash Imei: Empty
MasterCode:
Old 06-08-2011, 20:37   #15 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Server is ok now.
Time to close all threads with this problem.
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.25203 seconds with 9 queries
