06-09-2009, 17:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | why r not support intel flash chip (ANSWERED) b coz 1209 contect service not removed |
06-09-2009, 19:38 | #2 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Hi, please kindly explain clearly what kind of problem you have? And what you mean by intel chip flashing not support or why you're sure its not supported? BR. |
06-10-2009, 10:35 | #3 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
There is nothing like Intel Chips not supported my MXKEY. You may have problem with LCD, SIM Lock etc. Run a self tests and post log here. Br, Shadab Ahmad | |
06-11-2009, 06:57 | #5 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Processing file: rh105_05.910 ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 FlashID0: 0089 8872 [Intel] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Performing Flash Authentication ...OK UEM ID: 00983629:2984DA60 Programming MCU ... rh105_05.910: [DCT4][DCT4 ALGORITHM] size: 2.28 MB Area [01000000-0100FFFF] erased in 0.547 s Area [01010000-013AFFFF] erased in 31.328 s Area [013B0000-013EFFFF] erased in 2.360 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Error finalization ! Programming completed in 1 min 35.235 s File Processed in 2 min 23.547 s Processing file: rh1050_nai5.91md Performing Flash Authentication ...OK UEM ID: 00983629:2984DA60 Programming Content Pack ... rh1050_nai5.91md: [DCT4][DCT4 ALGORITHM] size: 147.47 KB Area [01380000-013AFFFF] erased in 1.547 s Flash programming ... Error finalization ! Programming completed in 1 min 2.422 s Content extract fail, continue anyway ... File Processed in 2 min 55.312 s Processing file: rh105_05.91md Performing Flash Authentication ...OK UEM ID: 00983629:2984DA60 Programming PPM ... rh105_05.91md: [DCT4][DCT4 ALGORITHM] size: 1.25 MB Area [01240000-0124FFFF] erased in 0.516 s Area [01250000-0137FFFF] erased in 10.454 s Flash programming ... Error finalization ! Programming completed in 1 min 19.328 s File Processed in 1 min 44.688 s Flashing completed in 8 min 8.141 s Phone not responding ! |
06-11-2009, 06:59 | #6 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | plz chek this it is intel chip i flash to mt box properly flash without any problem what is your answer i try to use jaf or hwk interface but problem is not solv |
01-03-2012, 09:31 | #7 (permalink) |
Freak Poster Join Date: May 2010
Member: 1308472 Status: Offline Sonork: mohd_nadeem231 Thanks Meter: 10 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0850248 Using device: HTI, FW ver: 00.50, SN: 00011D01 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1690020B71E37E56332DCF11DFD5E130F0F640B9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config what is the problem any hanset check showing this flash chip not suppoted plz help me |
01-03-2012, 09:47 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, please see the date of this thread. your case is irrelevant with current version. do not modify anything on config, unless you know what you are doing. config > do not mark BB5 use new protocol for rap3gv3 BR |
01-04-2012, 09:29 | #10 (permalink) |
Member: 1308472 Status: Offline Sonork: mohd_nadeem231 Thanks Meter: 10 | wan im flash the phone shwing thisVersion from phone: 07.30 Version from file: 07.30 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0850248 Using device: HTI, FW ver: 00.50, SN: 00011FAD Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\***_3519390375261 3_BACK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 16E00102DA4C7E56291A8E595C82ADA9510F659A ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [***] version: 10.32.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 e***ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config Task failed at (08000008)!!! Last RX buffer: 00 00 01 00 00 00 01 00 00 00 00 68 00 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
