02-14-2010, 16:14 | #1 (permalink) |
Junior Member Join Date: Jan 2010 Location: gsm world
Member: 1217869 Status: Offline Thanks Meter: 0 | 1661 flash problem please help me this is info when i press "buss check" : Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B742AFA3BDA66 ASIC type: 11 UEM Imei: 35692103204701 Flash Imei: 35692103204701 MasterCode: 0541456711 RPL saved to "C:\mobileEx\3.3\data\backup\35692103204701_BACK.r pl" Phone not responding ! |
02-14-2010, 16:20 | #2 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ((Hassan Mobile)) Age: 37
Member: 908729 Status: Offline Sonork: 100.1589748 Thanks Meter: 152 | Pls update your jaf firmware to FW ver: 01.B2 not in ver: 01.B1 |
The Following User Says Thank You to h_mobiles For This Useful Post: |
02-14-2010, 16:55 | #3 (permalink) |
Member: 1217869 Status: Offline Thanks Meter: 0 | i update my jaf box firmware to b2 but appear same error .please help Using device: J.A.F, FW ver: 01.B2 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B742AFA3BDA66 ASIC type: 11 UEM Imei: 35692103204701 Flash Imei: 35692103204701 MasterCode: 0541456711 RPL saved to "C:\mobileEx\3.3\data\backup\35692103204701_BACK.r pl" Phone not responding ! |
02-14-2010, 17:17 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | brother if ur set is dead then use ufs to flash or if u wanna to mx key then selct rm and select flash file manuly and flash |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
02-15-2010, 07:31 | #7 (permalink) | |
Member: 1217869 Status: Offline Thanks Meter: 0 | Quote:
1661 keypad problem | fonejack | Nokia Hardware & Hardware Repair | 32 | 03-02-2013 11:01 |
1661 light problem | neeraj1st | Nokia Hardware & Hardware Repair | 14 | 10-21-2011 16:08 |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
1661 light problem | nadeem126 | Nokia Hardware & Hardware Repair | 0 | 07-21-2009 09:00 |
Flash problem 1661 | ridowan | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-02-2009 13:44 |
