03-04-2010, 13:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | why there is error while repair i think server is also ok right now please check this BUS CHECK REPORT Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 05.20 15-10-08 RM-411 (c) Nokia Imei plain: 35684002113344-1 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! wHEN TRYING TO REPAIR SIM LOCK SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 05.20 15-10-08 RM-411 (c) Nokia Using cached productData[10A0010C9CB358506E747E35E1DD13C711B4D0CA] ... Calculating SIMLOCK using security server ... Completed in 1.656 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-411_356840021133441_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! WHEN REPAIR SD Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 05.20 15-10-08 RM-411 (c) Nokia Using cached productData[10A0010C9CB358506E747E35E1DD13C711B4D0CA] ... Calculating SUPERDONGLE using security server ... Completed in 3.672 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-411_356840021133441_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 why there is error |
03-04-2010, 13:29 | #5 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted DO FOLLOWING STEP complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. |
03-04-2010, 13:33 | #6 (permalink) |
Member: 405696 Status: Offline Thanks Meter: 148 | if not understand a video for you download . nokia 5220 contact service http://www.4shared.com/file/23004867...ntact_Ser.html |
Why there is no flash for 630???? | simplex | Redbox | 1 | 04-07-2005 11:45 |
Excuese Me!! Why there is not support for G8000 | MicrostarGSM® | Blazer | 0 | 10-06-2004 09:11 |
why there is no answer | mali_kruno | Cruiser Suite | 5 | 12-12-2003 11:24 |
Why there is no support for S46 in any flashing software??! | Disposable Hero | x1x to x45/x50 | 0 | 11-03-2003 15:42 |
Why there is no solution for sagem 936 | Bigbrothers2000 | Infineon C16X M51 & ARM7 M52 BASED | 0 | 05-18-2001 08:31 |
