02-10-2010, 06:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 7610 error flashing Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 008D2A01:2984DA7E ASIC type: 5 UEM Imei: 35227401259531 Flash Imei: 35227401259531 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35227401259531_BA CK.rpl" Processing file: RH51_52PE404214.C1 as MCU [WD2 BT2,WD2 ALGORITHM] size: 24.98 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 008D2A01:2984DA7E Area [00000000-0000FFFF] erased in 0.500 s Area [00010000-00FFFFFF] erased in 1 min 55.078 s Area [02000000-028FFFFF] erased in 1 min 4.515 s Area [02FC0000-02FEFFFF] erased in 1.406 s Flash programming ... Programming completed in 8 min 34.672 s File Processed in 12 min 1.360 s Processing file: RH51PE404214.20 as PPM [WD2 BT2,WD2 ALGORITHM] size: 1.89 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...Area [00000000-0000FFFF] erased in 0.469 s Area [02C00000-02DDFFFF] erased in 13.578 s Flash programming ... Error while programming [14] at 0x02C30000, Result: 0872 flashing terminated ! Flashing terminated with error(s) in 13 min 20.047 s RX Buffer: 0872 UFS2 SarasSoft disconnected. |
7610 error flash config | tabib.hape | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 11-24-2008 14:30 |
Error in 7610 while flashing .... | kit_kit | UFS2 + UFS3-Tornadoflasher | 3 | 07-10-2008 10:35 |
help me can not flash 6600 and 7610 error | not mobile | Griffin | 4 | 06-29-2005 15:46 |
