03-06-2012, 09:11 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725115 Status: Offline Thanks Meter: 84 | X1-01 Security Code Done Procedure Inside (TIPS) Pinout; Tools; Mxbox Ufc Cable MCU Flashfile DL Here Proceudre; 1.Connect Phone 2.Select Dct4 Check Xgold 3.INsert Mcu File 4.Bus Check 5.Select Reset All....Or Full Factory And Reset User Code |
03-06-2012, 09:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. no need to do reset code or full factory as you deleting all important data by this, the right procedure is after buscheck>service>imei & security>user code>click read user code & write it on a paper then disconnect phone from cable, power on phone, type user code, from menu>setting change code from user code to factory code 12345, thats without data lose, done by mxkey. this is the right solution. |
04-14-2012, 07:46 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Yes brother, you can use this procedure for all phones for removing user code(security) without deleting user data. |
04-14-2012, 20:14 | #6 (permalink) | |
Freak Poster Join Date: May 2011 Location: Pilipinas
Member: 1574276 Status: Offline Thanks Meter: 37 | Quote:
You wil also got code error or the code will not accepted another option Is try to full factory also all data will be erase regard's | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
