07-11-2013, 16:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 900764 Status: Offline Sonork: ng Thanks Meter: 17 | x2-00 hang. Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 241F64A6 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35623604979489_CE RT.rpl). CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 32.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-011BFFFF] CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF] CMT FLASH,MuxOneNAND area [02500000-028FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT ADA block sent CMT RAP3NAND block sent CMT ISA+DYNSW block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT UPDAPP block sent Programming completed in 9.687 s Processing PPM file: rm618__08.35.ppm_mh [BB5,XSR 1.6] size: 6.37 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01D00000-024FFFFF] Flash programming ... Programming completed in 2.062 s Processing CNT file: rm618__08.35_007.image_mh_ctv_in_9f8g7 [BB5,XSR 1.6] size: 20.62 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 76.31 MB CMT FLASH,MuxOneNAND area [02900000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 7.125 s Total time for flashing process(boot+erase+write) was 32.078 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 241F64A6 Waiting for USB device removal ...OK Waiting for USB device arrival ... Warning: Phone did not reboot to normal mode. [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! |
07-12-2013, 05:56 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | since you cut the logs, i cant see your mobileex version. make sure you are using 3.5rev2.6 and synchronized. - flash with lower MCU version, and back to higher version directly. check. |
