05-20-2013, 11:41 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231601 Status: Offline Thanks Meter: 13 | x2-01 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0856E16 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000003C25A85B2EFD0B7BBAA9E6E6CF05A8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Selected firmware certificate matched. Original Imei: 35739104410847 Original Product code: 059C3R0 Bluetooth ID: 78CA04866751 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E Waiting for USB device removal ... Device connected: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 357391044108472 Verifying communication to device... ERROR: Could not verify communication ! [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! how to fix thise |
05-20-2013, 12:47 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Flash with Latest Firmware of it's Product Code, Will appear in Test Mode after Flash Process over, Now Reset User Code or apply Factory Reset. BR, ZUBER |
05-25-2013, 11:53 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ghana
Member: 320120 Status: Offline Thanks Meter: 98 | I have about three x2-01 phones. The problem is that, when i try to play ringtone the set will restart. I flashed it, i also change the ringer but no to answer. Any person with solution? Thanks |
