04-19-2010, 15:54 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | 6300 and 3110c security test failed Phone Type: RM-217 (Nokia 6300) SW Version: V 06.60 21-05-08 RM-217 (c) Nokia. Imei plain: ************** Product Code: ***** Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: *********** Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF same for 3110c also Need Help Please This all hapend by writing PM |
04-19-2010, 16:03 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | @ ajit bs brother, why u seeking help???? do u search the mxkey section??? by the way do the following job. hope ur problem ill be solve backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd go to pm >click sd auth writ pm reply here, if u still face this problem |
The Following 4 Users Say Thank You to sanjoychy For This Useful Post: |
04-19-2010, 17:59 | #4 (permalink) | ||
Member: 772651 Status: Offline Thanks Meter: 1,694 | Quote:
actually brother when both sets came to were ok, both had a network problem . when i scan both sets with mx-key it shown SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed then i wrote PM and again made a scan it shown SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! then itried to switch on the both sets 6300 & 3110c .. both got in contact service where as imei number of both sets are ok now when i m trying to write with 1 and 309 field it shows warrning failed to write 1 and 309 field please help step by step so that i can solve my problem | ||
04-19-2010, 18:17 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | pls do it step by step 1_mxkey>serves>imei&securty>imei rebuild>repair sd 2_go to pm >click super sd auth and writ pm 3_full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-19-2010, 19:13 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan
Member: 386511 Status: Offline Thanks Meter: 305 | pls do it step by step 1_mxkey>serves>imei&securty>imei rebuild>repair sd 2_go to pm >click super sd auth and writ pm 3_full factory try............................... |
The Following 2 Users Say Thank You to tanveeranjum For This Useful Post: |
04-20-2010, 06:31 | #11 (permalink) |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | @ ajit bs Brother sorry for late response. hope still u have faced this problem just connect ur phone with mx key. Go Service > Imei & Security > Imei Rebuild then click Write Rpl option and write these rpl. and post the result |
04-20-2010, 13:01 | #12 (permalink) | |
i tried .... i did ist repair SD and then in PM tab i did SUPER SD Auth. with PM 1 and 309 ..i got this error Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[26C0010399357C56FEFA869E9631022A40D10FAA] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 0.500 s need immidite help | |
04-20-2010, 13:08 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INSIDE THIS FLAG
Member: 660737 Status: Offline Thanks Meter: 105 | Quote:
The Following User Says Thank You to unicomtogo For This Useful Post: |
04-20-2010, 13:12 | #14 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | bro, u need erase pmm backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click sd auth and writ pm fullfactory |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
