08-06-2011, 14:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: NIGERIA
Member: 1540810 Status: Offline Sonork: 100.1627394 Thanks Meter: 161 | x2-01 FLASH COMPLETE WITH MX BOX Driver: nmwcdc, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35741004695067_BA CK.rpl). Processing MCU file: rm709__08.63.mcusw [BB5,XSR 1.6] size: 26.59 MB Supported Ids: 2200050920030000, 22000509200C0000 Battery voltage: 3724 mV Warning battery voltage is less, phone might not detected after flash ! Phone type: RM-709 Product code: 059G326 SW version: V 07.10 28-10-10 RM-709 (c) Nokia LanguagePkg version: V 07.10 28-10-10 RM-709 (c) Nokia MN1 Version from phone: 07.10 Version from file: 08.63 Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 152AF5C CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 000000000068DFE03EA989D385DA2475B15E94D7 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0010 0011 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 152AF5C Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35741004695067_CE RT.rpl" CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] OK. Partitioning.... Partitioning complete Erase size: 33.88 MB CMT MuxOneNAND area [00000000-0001FFFF] CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-012FFFFF] CMT MuxOneNAND area [01300000-01DFFFFF] CMT MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6FC432998EF0DB240E332228384D19ED09 () sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 7.640 s Processing PPM file: rm709__08.63.ppm_i2 [BB5,XSR 1.6] size: 5.59 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.641 s Processing CNT file: rm709__08.63.image_i2_059C3Q2 [BB5,XSR 1.6] size: 29.92 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 8.484 s Total time for flashing process(boot+erase+write) was 37.406 s Waiting for device boot up ... Device found: nmwcdc\Nokia USB Phonet, PORT_ID: 2F347F19 Verifying communication to device OK. After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-709 (X2-01) SW Version: V 08.63 25-03-11 RM-709 (c) Nokia Imei plain: 35741004695067-1 Product Code: 059G326 Battery voltage: 3724 mV, current: 1 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357410046950671 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following User Says Thank You to Engiess For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
