05-04-2011, 09:08 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Age: 39
Member: 568124 Status: Offline Thanks Meter: 15 | !!x2-01 usercode via usb problem!! Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1EE36FBB CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000002A71D685CE087ED05B75AC6196D60A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0010 0011 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1EE36FBB Verifying communication to device OK. Waiting for device boot up ... Device found: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 3B139622 Verifying communication to device... Verifying communication to device... Communication lost, phone not found. Reset User Code (to default:12345) ... Failed! Completed in 5.015 s FULL FACTORY... Failed! Completed in 5.015 s Nokia C3-00 USB Phonet detached. and also phone detecting as c3-00 also no info reading |
05-04-2011, 11:59 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | usercode reset requires phone in test mode, after booting phone, try manually changing mode from the drop down menu to test mode and see if phone goes into test then u should succced |
04-23-2012, 15:44 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. try this way:http://forum.gsmhosting.com/vbb/f550...1/#post8207983 bro. no need to do reset code or full factory as you deleting all important data by this, the right procedure is after buscheck>service>imei & security>user code>click read user code & write it on a paper then disconnect phone from cable, power on phone, type user code, from menu>setting change code from user code to factory code 12345, thats without data lose, done by mxkey. this is the right solution. |
04-23-2012, 17:34 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | u can not reset user code of in specially in x2-01 ,u need to full flash the handset ..some newer phone's user code are encrypted. You will need to flash to remove it codes. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
