11-21-2010, 14:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: SUNDARBAN.THE MAGICAL MANGROVE
Member: 1432362 Status: Offline Thanks Meter: 39 | X2 ..dead by mx-key.whats i will do? (solved) SET COMING WITH SECURITY CODE I TRY TO USB FLASHING.BUT ITS NOT FLASH....JUST HANG IN .((FLASH PROGRAMING......) AFTER FEW MINUTITS ITS SAID................LOG.. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm618__04.90.mcusw [BB5,XSR 1.6] size: 26.74 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3A32FE7F CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: C809207C07ABBE55F92DAAEEBC102E20313290D3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3A32FE7F Verifying communication to device OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 32.88 MB Flash programming ... WriteDevice failed: Failed to read/write device Error while programming [00] at 0x00000000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 7 min 38.906 s RX Buffer: 80106F00 PHONE IS NOW DEAD. I TRY MANY TIME , WITH DIFERESNT PC ..BUT SAME RESULT. WHAT SHOULD I DO? PLEASE............... |
11-21-2010, 14:48 | #3 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | Have taken all backup before flash ??? just write RPL and the phone will come to same state as it was and charge battery fully before flash .... BR / Manbir |
11-22-2010, 06:29 | #5 (permalink) |
Member: 1432362 Status: Offline Thanks Meter: 39 | at last its done Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm618__04.90.mcusw [BB5,XSR 1.6] size: 26.74 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device .. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1AF2FEED CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: C809207C07ABBE55F92DAAEEBC102E20313290D3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1AF2FEED Verifying communication to device OK. CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 32.88 MB Flash programming ... CMT PAPUBKEYS: E9700989029D9E899915F781B1582048E042A738 (RAP Certificate v1 237) written. Programming completed in 8.984 s Processing PPM file: rm618__04.90.ppm_ms [BB5,XSR 1.6] size: 6.07 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8.00 MB Flash programming ... Programming completed in 2.172 s Processing CNT file: rm618__04.90.image_ms_0595278_005 [BB5,XSR 1.6] size: 20.29 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 76.31 MB Flash programming ... Programming completed in 7.000 s Total time for flashing process(boot+erase+write) was 29.890 s Pooling for ADL device ... Device found: nmwcdc\Nokia X2-00 USB Generic, ID: 3A6BE0B Verifying communication to device OK. Flashing completed in 51.047 s Phone Type: RM-618 (Nokia X2-00) SW Version: V 04.90 28-09-10 RM-618 (c) Nokia Imei plain: 35342304215617-1 Product Code: 0595278 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353423042156171 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.687 s Nokia USB ROM detached. thanks |
The Following User Says Thank You to IMET.BD For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
