x3-02 i have x3-02 phone its camera opration faild standby its bus check logs MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0856E16 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 03C0010118A70344A85CE888FA09C1191E8E4D32 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Selected firmware certificate matched. Original Imei: 35376404520914 Original Product code: 0598435 Bluetooth ID: 2CD2E770461E SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia X3 Touch and Type USB Phonet, PORT_ID: 35269964 Verifying communication to device OK. Phone type: RM-639 (Nokia X3-02) SW version: V 05.60 06-10-10 RM-639 (c) Nokia Imei plain: 35376404520914-9 Product code: 0598435 Battery voltage: 4003 mV, current: 143 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353764045209149 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN selftest Phone Type: RM-639 SW version: V 05.60 06-10-10 RM-639 (c) Nokia ID Test name Startup Result 232 USB_CHARGER N passed 88 TAHVOINT Y passed 15 SLEEP_X_LOOP N passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP N passed 12 SIM_CLK_LOOP N passed 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 69 BACKLIGHT Y passed 20 BACKUP_BATT Y passed 43 LCD N passed 44 LPRF_AUDIO_LINES N passed 21 LPRF_IF N passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N !no signal 71 BT_WAKEUP N passed 96 HOOKINT N passed 101 BTEMP N passed 8 MBUS_RX_TX_LOOP Y passed 72 WLAN N passed 23 KELVIN_BATVOLTAGE N passed 19 KELVIN_VIBRA N passed 26 KELVIN_CAPACITOR N passed 29 KELVIN_MISC N passed 31 KELVIN_CHARGING N passed 27 KELVIN_AUDIO N passed 116 KELVIN_XEAR N passed 60 TOUCH_STUCK N passed 103 TOUCH_IF N passed 105 INTERNAL_ANTENNA N passed 119 IIC N passed 91 USB_LOOP N passed 117 DIGIMIC N passed 209 HEADSET_AMPLIFIER N passed 222 LED_CONTROLLER N passed 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 124 CDSP_STROBE N !NOT EXECUTED(03) 125 CDSP_DIGI_RXTX_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 127 CDSP_PA_ID_PIN N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) |
replace if not.... |
Bro. Check Camera contacts, Check VCam Volt & ways, Follow Schematic. It's Hardware. BR, ZUBER |
