Old 10-12-2012, 10:01   #1 (permalink)
Member: 1231601
Thanks Meter: 13
x3-02
i have x3-02 phone its camera opration faild standby
its bus check logs
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0856E16
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00005C74
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 03C0010118A70344A85CE888FA09C1191E8E4D32
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C
Selected firmware certificate matched.
Original Imei: 35376404520914
Original Product code: 0598435
Bluetooth ID: 2CD2E770461E
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X3 Touch and Type USB Phonet, PORT_ID: 35269964
Verifying communication to device OK.
Phone type: RM-639 (Nokia X3-02)
SW version: V 05.60 06-10-10 RM-639 (c) Nokia
Imei plain: 35376404520914-9
Battery voltage: 4003 mV, current: 143 mA
Language Pack:
- not available.
SLPA ver[5]: PA_SIMLOC30 (20 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353764045209149
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
selftest
Phone Type: RM-639
ID Test name Startup Result
232 USB_CHARGER N passed
88 TAHVOINT Y passed
15 SLEEP_X_LOOP N passed
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP N passed
12 SIM_CLK_LOOP N passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N passed
69 BACKLIGHT Y passed
20 BACKUP_BATT Y passed
43 LCD N passed
44 LPRF_AUDIO_LINES N passed
21 LPRF_IF N passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N !no signal
71 BT_WAKEUP N passed
96 HOOKINT N passed
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y passed
72 WLAN N passed
23 KELVIN_BATVOLTAGE N passed
19 KELVIN_VIBRA N passed
26 KELVIN_CAPACITOR N passed
29 KELVIN_MISC N passed
31 KELVIN_CHARGING N passed
27 KELVIN_AUDIO N passed
116 KELVIN_XEAR N passed
60 TOUCH_STUCK N passed
103 TOUCH_IF N passed
105 INTERNAL_ANTENNA N passed
119 IIC N passed
91 USB_LOOP N passed
117 DIGIMIC N passed
209 HEADSET_AMPLIFIER N passed
222 LED_CONTROLLER N passed
128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
124 CDSP_STROBE N !NOT EXECUTED(03)
125 CDSP_DIGI_RXTX_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
127 CDSP_PA_ID_PIN N !NOT EXECUTED(03)
75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03)
Old 10-12-2012, 10:31   #2 (permalink)
Member: 1325931
Sonork: 100.1606274
Thanks Meter: 38
here is your problem.....check if ok
replace if not....
Old 10-12-2012, 10:55   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Check Camera contacts,
Check VCam Volt & ways,
Follow Schematic.
It's Hardware.
BR,
ZUBER
Page generated in 0.24066 seconds with 7 queries
