Member: 1145079
Sonork: 100.1586176 Thanks Meter: 28 | After Rehot Flash And Update Software My phone Now Work good Quote:
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] -
Driver: NMWCD, ver: 7.1.32.65
Module ver: 1.0.0.17744(26-06-2011), Library ver: 1.0.0.11773(23-06-2011)
Processing MCU file: rm540__08.54.mcusw
[BB5,XSR 1.6] size: 26.10 MB
Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 14B948AE
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102054100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 35400114494A00497ABF82BEED5359A8D3A6E632
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Storing certificate [NPC, CCC, HWC, R&D] OK.
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: CEFA9C41 [RAP Certificate 193 v.1] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 32.375 s
Processing PPM file: rm540__08.54.ppm_f
[BB5,XSR 1.6] size: 5.66 MB
Erase size: 8.87 MB
CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 7.032 s
Processing CNT file: rm540__08.54.image_f_0580818_006
[BB5,XSR 1.6] size: 15.29 MB
Erase size: 75.06 MB
CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 19.234 s
Total time for flashing process(boot+erase+write) was 1 min 15.469 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia X3 USB Phonet, PORT_ID: 107C0A1
Verifying communication to device OK.
Phone Type: RM-540 (Nokia X3-00)
SW Version: V 08.54 25-10-10 RM-540 (c) Nokia
Imei plain: 35379604973040-7
Product Code: 0583972
Battery voltage: 3985 mV, current: 76 mA
Language Pack:
- not available.
Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353796049730407
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
