06-12-2011, 23:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | x3 not unlock (CLOSED - RULE 6) Version: SIMLOCK SERVER Provider: O2 UK Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23410F [United Kingdom-O2 UK Ltd. ] #pw+ 630769309284291 +1 # #pw+ 981481148839917 +2 # #pw+ 417386965213142 +3 # #pw+ 525395454947013 +4 # #pw+ 880984384917615 +5 # #pw+ 167838429721833 +6 # #pw+ 135612551104305 +7 # Codes file saved to: C:\mobileEx\3.5\data\SL3\351536043119070_SP_CODES. txt Sending NCK code ... Trying NCK lock 7 ...Trying NCK lock 6 ...Trying NCK lock 5 ...Trying NCK lock 4 ...Trying NCK lock 3 ...Trying NCK lock 2 ...Trying NCK lock 1 ... Reading Simlock info ... Imei net: 351536043119070 Version: SIMLOCK SERVER Provider: O2 UK Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23410F [United Kingdom-O2 UK Ltd. ] manually also entered but always wrong codes #pw+ 630769309284291 +1 # #pw+ 981481148839917 +2 # #pw+ 417386965213142 +3 # #pw+ 525395454947013 +4 # #pw+ 880984384917615 +5 # #pw+ 167838429721833 +6 # #pw+ 135612551104305 +7 # |
06-13-2011, 23:06 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | this is from the latest stand alone internal beta version, please try #pw+397378434396556+1# #pw+437140710535712+2# #pw+729794375369332+3# #pw+660649530651545+4# #pw+700508924772293+5# #pw+389118905432643+6# #pw+927679310962767+7# if already counter blocked, please reset it first. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
06-14-2011, 13:40 | #7 (permalink) | |
Member: 648590 Status: Offline Thanks Meter: 267 | Quote:
work new thanx but what is the problem for me | |
08-23-2011, 12:57 | #8 (permalink) | |
Banned Sonork: 100.1616308 Thanks Meter: 33 | Quote:
12-24-2011, 18:55 | #9 (permalink) |
Registered User Join Date: Oct 2005 Location: e g y p t Age: 43
Member: 194178 Status: Offline Sonork: 100.1594302 Thanks Meter: 34 | #pw+ 240201164259881 +1 # #pw+ 291293708207754 +2 # #pw+ 371609248647245 +3 # #pw+ 054393295580867 +4 # #pw+ 073711337716657 +5 # #pw+ 636850741860618 +6 # #pw+ 503908040810738 +7 # Codes file saved to: C:\mobileEx\3.5\data\SL3\357912042190509_SP_CODES. txt Sending NCK code ... Trying mode: FBUS, NCK lock 7(ALL) ...FAILED: wrong code Trying mode: FBUS, NCK lock 6(MCCMNC+GID1+GID2) ...FAILED: not ready Trying mode: FBUS, NCK lock 5(MCCMNC+GID1) ...FAILED: wrong code Trying mode: FBUS, NCK lock 4(IMSI) ...FAILED: not ready Trying mode: FBUS, NCK lock 3(GID2) ...FAILED: wrong code Trying mode: FBUS, NCK lock 2(GID1) ...FAILED: not ready Trying mode: FBUS, NCK lock 1(MCCMNC) ...FAILED: wrong code Reading Simlock info ... Imei net: 357912042190509 Version: SIMLOCK SERVER Provider: Vodafone Espaٌa, SAU , Country: Spain Counter: 0/3, 4/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=21401F [Spain-Vodafone Espaٌa, SAU ] same here |
12-24-2011, 19:24 | #10 (permalink) | |
Member: 194178 Status: Offline Sonork: 100.1594302 Thanks Meter: 34 | Quote:
12-26-2011, 15:16 | #11 (permalink) | |
12-27-2011, 20:13 | #13 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | You can unlock it by yourself if you have HTI (MXBOX). Can have this result: Code: Connection status: EHCI:HUB:HUB:HUB:HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) Boot ver: 01.09, Box SN: 01001012 FW version: 00.50 MXKEY serial: C081653B Active Licenses: BB5: 1, DCT4PLUS: 1, SL3: 1 HTI SL3 Logger ready. Imei: 357912042190509 Simlock Hash: 3F311273B59876DF0CEA590FDA06537EB886B8EE Master SP: 0301070900006B20486173683A2000 SX5 serial: 000000 #pw+ 24020116425xxxx +1 # #pw+ 29129370820xxxx +2 # #pw+ 37160924864xxxx +3 # #pw+ 05439329558xxxx +4 # #pw+ 07371133771xxxx +5 # #pw+ 63685074186xxxx +6 # #pw+ 50390804081xxxx +7 # Codes file saved to: C:\mobileEx\3.5\data\SL3\357912042190509_SP_CODES.txt BR, Manole |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
