Old 07-05-2010, 07:09   #1 (permalink)
Crazy Poster
Member: 805005
Thanks Meter: 46
X3 Security Code DONE via USB w/out FLASHING by MxKey!!!
You need corresponding USB cable and mxkey..
Open Mxkey
Select Nokia USB ROM then connect
Select Nokia Tools(BB5 tab)
Select Model(X3)
Select flashfile(to detect phone in bus check )
Click bus check(if the phone detected and shows the info,proceed to the next step)
Click Service then Reset all..
DONE
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 10D31CA4
RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x]
RAP EM0 ID: 00001040
RAP EM1 ID: 00001030
RAP PUBLIC ID: 33E0000ECDE80C49220C644241A265F2A1D827B4
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
RAP ROM ID: 67E82268F29CEA60
[ADL] Loading CMT secondary boot code
 SecondaryBoot: rap3gv40_2nd.fg [BB5]  version: 9.48.0 revision: 2.1 size: 0x3BC0
 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
[ADL] Secondary boot loaded.
FlashID0: 0000 0000  - 0000 0000 [unused/removed] type: NOR,RAP
FlashID1: 0000 0001  - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 00EC 0030  - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP
[ADL] Loading CMT Update Server Data
 Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6]  version: 9.48.0 revision: 2.1 size: 0x7E232
[ADL] Update Server code loaded.
[ADL] Verifying communication to device OK.
[ADL] Device found: nmwcdc\Nokia  USB Generic, ID: 1AA22031
Phone Type: RM-540 (Nokia X3-00)
SW Version: V 03.60 21-10-09 RM-540 (c) Nokia
Imei plain: 357977
Product Code: 0581085
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 357977
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.782 s
The Following 36 Users Say Thank You to kc1_express For This Useful Post:
Old 07-05-2010, 07:28   #2 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
gud info...................................
Old 07-05-2010, 07:37   #3 (permalink)
kumarphuyal's Avatar
Member: 659612
Thanks Meter: 15
धन्यवाद...................................... .
Old 07-05-2010, 08:13   #4 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
Thanks Meter: 327
nice tread but you are using old version of mxkey
Old 07-05-2010, 09:47   #5 (permalink)
Crazy Poster
Member: 1118992
Sonork: 100.1622295
Thanks Meter: 3
mx key
my mx key is showing flash option. not showing service option. in usb rom
Old 07-05-2010, 11:12   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if you follow this instruction , you will get TAB SERVICE in MXKEY
Open Mxkey
Select Model(X3)
@kc1_express
thanks for report
br,
The Following 4 Users Say Thank You to Andra For This Useful Post:
Old 07-05-2010, 11:18   #7 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
thankz for sharing.. keep up the good work.
Old 07-05-2010, 11:36   #8 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
Open Mxkey
Select Model(X3)
DONE
Imei plain: 357977
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 357977
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
it is really nice. last week somebody is telling that he can catch Manole. i said you cant coz the man is running like turbo and his cock alim hape hold the gsm nuclear weapons
The Following User Says Thank You to unicomtogo For This Useful Post:
Old 07-05-2010, 11:59   #9 (permalink)
parvez10's Avatar
Member: 1309082
Thanks Meter: 20
bro,
thanks for sharing...
Old 07-05-2010, 12:15   #10 (permalink)
Crazy Poster
Member: 805005
Thanks Meter: 46
sorry for that..
my MxKey's not yet activated, thats why it is old version..
@tom14300
follow my instruction and you'll see the service tab, like Andra said
br,
Old 07-05-2010, 15:22   #11 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
@kc1_express
thanks for report
br,
i do same but not shoe service option
Old 07-05-2010, 17:19   #12 (permalink)
Member: 583454
Thanks Meter: 80
^ plz click bus check then efter detection of phone we have service option there !!!!!!!!!!!!!!!!!
Old 07-05-2010, 17:34   #13 (permalink)
Member: 773516
Sonork: 100.1583311
Thanks Meter: 69
not all model of nokia is supported with this option
Old 07-05-2010, 17:36   #14 (permalink)
Member: 644871
Thanks Meter: 2
nice info, thank you.bye.
Old 07-06-2010, 01:37   #15 (permalink)
Crazy Poster
Member: 805005
Thanks Meter: 46
click Bus check first...
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 04:40
Page generated in 0.31283 seconds with 10 queries
