06-23-2011, 09:39 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | x6 nokia did not power on give only vibration and keypad light glowing (ANSWERED) but give info with f bus here is self test log but not power on Phone Type: RM-559 (Nokia X6-00) SW Version: V ICPR72_09w36.20 31-12-09 RM-559 (c) Nokia Imei plain: 35200604013373-9 Product Code: 0598169 Battery voltage: 4364 mV, current: 94 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352006040133739 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN Phone Type: RM-559 SW version: V ICPR72_09w36.20 31-12-09 RM-559 (c) Nokia ID Test name Startup Result 88 TAHVOINT Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 90 PWR_KEY N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 8 MBUS_RX_TX_LOOP Y !NO SIGNAL(06) 32 AMB_LIGHT_SENSOR N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 117 DIGIMIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
06-23-2011, 11:41 | #3 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | after full flash my handset same problem MXKEY Serial: [MxKey HTI FLASHER INTERFACE 5] - C08543E8 Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.6.0.0, NTMP ver: 2.6.2.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: RM-559_31.0.004_prd.core.C00 [BB5,XSR 1.6] size: 110.41 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04800005018F005299F238D82A73C7AEBA1BB4B7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 2.0 size: 0x8F51C Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 182.94 MB CMT MuxOneNAND area [00040000-00082FFF] CMT MuxOneNAND area [00083400-003FFFFF] CMT MuxOneNAND area [00400000-007FFFFF] CMT MuxOneNAND area [00800000-00D5FFFF] CMT MuxOneNAND area [00D60000-0B71FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E00DA77BF32983F864BC7671FE7709A29D8E2C08 (RAP Certificate 191 v.1) sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 5 min 4.828 s Processing PPM file: RM-559_31.0.004_prd.rofs2.V01 [BB5,XSR 1.6] size: 24.47 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04800005018F005299F238D82A73C7AEBA1BB4B7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 2.0 size: 0x8F51C Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Erase size: 41.87 MB CMT MuxOneNAND area [07920000-0A2FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 1 min 9.735 s Processing PPM file: RM-559_31.0.004_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 4.97 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04800005018F005299F238D82A73C7AEBA1BB4B7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 2.0 size: 0x8F51C Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Erase size: 20.12 MB CMT MuxOneNAND area [0A300000-0B71FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 14.453 s Processing CNT file: RM-559_31.0.004_001_000_U001.uda.fpsx [BB5,XSR 1.6] size: 7.81 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04800005018F005299F238D82A73C7AEBA1BB4B7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 2.0 size: 0x8F51C Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Erase size: 312.37 MB CMT MuxOneNAND area [0B720000-1EF7FFFF] Converting UCP blocks to 128 K. Flash programming ... Programming completed in 21.359 s Total time for flashing process(boot+erase+write) was 7 min 22.906 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-559 (Nokia X6-00) SW Version: V ICPR72_10w42.1 23-11-10 RM-559 (c) Nokia Imei plain: 35200604013373-9 Product Code: 0598169 Battery voltage: 4732 mV, current: 112 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352006040133739 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
