Old 06-27-2010, 18:43   #1 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
6120C Test Mode
only 6120C Test Mode when put battery
try to flash it in both usb and fbus but not respond
what is solution
Old 06-27-2010, 19:15   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
what is solution
Bro, i thinks its hardware problem, can you post the error log, first clean it carefully and make sure there is no shorting in the circuit(check all the connector and clean it carefully), if problem still persist, check the cpu, rehot it carefully, also check power ic.
BR,\
curv
Old 06-28-2010, 07:11   #3 (permalink)
Member: 473926
Thanks Meter: 46
6120c test mode and local mode 100% ok
just check the picture and wash your board
The Following 4 Users Say Thank You to nicearif For This Useful Post:
Old 06-28-2010, 07:37   #4 (permalink)
tariq_h's Avatar
Member: 896307
Sonork: 0096
Thanks Meter: 231
thank u nicearif,well done body
My 5130 shows 25 mA in stdby, another 4mA in Netmonitor test 23 mr_x4you Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-23-2001 11:07
only Test zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-29-2000 21:43
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-20-2000 16:39
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-01-2000 23:47
Page generated in 0.14049 seconds with 9 queries
