02-04-2010, 13:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | Cant Repair Security Test Failed on N96 and 5800 i have repaired by mxkey. ButNow the phones have SECURITY_TEST failed! here is info of N96: Code: Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35932002237556-1 Product Code: 0573319 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359320022375561 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 85.105.105.64 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-07-2010, 02:59 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | litle bit spend time with searching button u will get [MXKEY - INFO] !!! NEW magic button inside mxkey !!! and Just in case if Recovery via Server doesn't work....... and Repair SUPERDONGLE br, |
02-07-2010, 08:26 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
you are graet for mx-key tream BR. | |
02-07-2010, 09:28 | #5 (permalink) | |
Freak Poster Join Date: May 2009 Location: venezuela Age: 32
Member: 1027249 Status: Offline Thanks Meter: 24 | Quote:
includes N96 and 5800 and if after writing follows the failure then download these modified PM but remember before writing the PM must write the RPL before http://www.4shared.com/file/21605830...-Clan_gsm.html | |
02-07-2010, 10:45 | #7 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Russia
Member: 135631 Status: Offline Thanks Meter: 26 | 5800d-1 SECURITY_TEST failed! I also have not received 2 phones 5800d-1 and n70. SECURITY_TEST failed! This solution is not suitable for them. However, the 7210, 5220 was successful |
02-07-2010, 19:07 | #8 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Дніп&#
Member: 33296 Status: Offline Thanks Meter: 20 | i am too have 5800d-1b with SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request my 8600 (luna) repair ok and work fine |
02-07-2010, 19:58 | #9 (permalink) |
Member: 33296 Status: Offline Thanks Meter: 20 | When do "BB5 sertificate validation": RAP PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Reading RAP NPC (0x190 bytes) Original Product Code: 0577454 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0583430 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0577218 Product Code missmatch ! how to change product code? |
02-08-2010, 06:38 | #10 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | after [MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" please give report br, |
02-08-2010, 14:52 | #11 (permalink) |
Insane Poster Join Date: Apr 2006 Location: Venezuela
Member: 259110 Status: Offline Thanks Meter: 11 | Hello i need some help here! i follow all these post but i still have the same problem security test failed, i check BB5 Certificate Validation and i get this: Reading RAP NPC (0x1B8 bytes) Original Product Code: 0543713 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0543727 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0543713 HWC seems to be valid please help me |
02-09-2010, 04:54 | #15 (permalink) | ||
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
write PM except [308] Quote:
where the log ? br, | ||
N96 screen flickers after repair security test failed., Some solutions to this proble | Hacker84 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-19-2010 22:53 |
I can't repair Security Test Failed on N96 | gsmlife | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 02-08-2010 06:44 |
Solution to repair Security Test Failed | fretburner | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-07-2010 04:16 |
after sd repair SECURITY TEST failed | mobitechnepal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-04-2010 08:41 |
Post sucessfull SD Repair + Security Test Failed | cel_phon | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-04-2010 06:51 |
