06-23-2010, 21:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | pm308 is readonly when I write backup RPL Code: Imei: 35xxxxxxx Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0570923)... OK Updating PSN (CAN834475)... OK Updating HWID (2001)... OK Updating SIMLOCK...OK Trying to update SUPERDONGLE_KEY(from PM308 backup)...error 0x0 PM308 is readonly? Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-470 (Nokia 6700 classic) SW Version: V 10.50 23-11-09 RM-470 (c) Nokia Imei plain: 35xxxxxxxxxxxxxxxxx Product Code: 0570923 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35xxxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
06-24-2010, 19:02 | #5 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | Do you mean Mx-key can repair this w/o rpl? Code: SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. But if you know other solution... I am wait listen to you, instruction step by step. |
06-24-2010, 21:05 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | YES as LEENO said, UNLOCK is not SUPPORTED YET , but SD Repair is SUPPORTED. dont forget to backup SIMLOCK , FULL RPL , and FULL PM before any operation ps : about SD repair instruction is same as usually if get any error please send full details info here br, |
06-25-2010, 04:53 | #8 (permalink) | ||
Member: 219015 Status: Offline Thanks Meter: 42 | Quote:
Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Original Imei: 35318103799354 Original Product code: 0570923 Bluetooth ID: 002669ECB75C Phone Type: RM-470 (Nokia 6700 classic) SW Version: V 10.50 23-11-09 RM-470 (c) Nokia Imei plain: 3531xxxxxxxx-1 Product Code: 0570923 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3531xxxxxxxxxx1 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V 10.50 23-11-09 RM-470 (c) Nokia SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Custom loader not available for this ID ! Code: RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Begin Certificate Request ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1 Updating PRODUCTCODE (0570923)... OK RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! Code: Imei: 353xxxxxxxxx1 Restoring RF/BB DATA from backup ... RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Erasing CMT NPC ... OK Updating RF ...error 0x0 Updating BB ...error 0x0 Updating WARRANTY ...error 0x0 Updating PROD ...error 0x0 Updating BT ...error 0x0 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0570923)... OK Updating PSN (CAN834475)... OK Updating HWID (2001)... OK Updating SIMLOCK...OK Trying to update SUPERDONGLE_KEY(from PM308 backup)...error 0x0 PM308 is readonly? Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-470 (Nokia 6700 classic) SW Version: V 10.50 23-11-09 RM-470 (c) Nokia Imei plain: 353xxxxxxxxx1 Product Code: 0570923 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353xxxxxxxxx1 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF 2LEENO Quote:
06-25-2010, 09:45 | #12 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Quote:
06-25-2010, 18:04 | #13 (permalink) | |
Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V 10.50 23-11-09 RM-470 (c) Nokia SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Custom loader not available for this ID ! | |
06-25-2010, 21:30 | #14 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | use loaders 9.50 and jafbox and repair sd. If not work, click buscheck and post result |
The Following User Says Thank You to LEENO For This Useful Post: |
06-27-2010, 10:50 | #15 (permalink) | |
Code: Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 TransmissionMode: DDR&TX2 Original Imei: 35xxxxxxxxxxxx Original Product code: 0570923 Bluetooth ID: 002669ECB75C Phone Type: RM-470 (Nokia 6700 classic) SW Version: V 10.50 23-11-09 RM-470 (c) Nokia Imei plain: 35xxxxxxxxxxxx Product Code: 0570923 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35xxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F400210C5600344D2E613C784A5FEC582CEA24B ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 New Protocol is not supported for the current interface (POTATO BOX, FW ver: 01.B1). Please select correct loader version from 'Config' menu ! | |
The Following User Says Thank You to Freshbol For This Useful Post: |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
