Old 02-19-2012, 02:12   #1 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
E6-00 RM-609 Won't Flash CNT (ANSWERED)
Ok, I've tried numerious attempts to flash this phone but I can't seem to flash the "CNT" Following is log:
PHP Code:
MXKEY [FT SCR2000 0], SNJabbacks
Using device
USB ROM
Connection status
EHCI:HUB::USB 2.00 (High-speed)
DriverNMWCDver7.1.32.70
Module ver
1.0.0.19798(05-01-2012), Library ver1.0.0.13703(05-01-2012)
Processing MCU fileRM-609_111.130.0625_79_prd.core.fpsx
[BB5,XSR 1.6]  size137.77 MB
 Supported Ids
4003192102001104400C1921020011046003192102001104600C1921020011046003192102011104600C1921020111046003192102021104600C1921020211046003192102031104600C192102031104
Make sure USB cable
Battery and charger are removed from device.
Insert USB cableBattery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1DC8C125
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 18D00004F6D80344AEBD4EDCC9CF4511CCEA0AE8
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
 SecondaryBoot: RAPUv11_2nd.fg [BB5]  version: 11.14.0 revision: 3.0 size: 0x3B40
 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0020 0068  - 0000 0031 [ST  LH28F160BG] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0068  - 0000 0031 [ST  LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
Loading CMT update server data
 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6]  version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x1E4 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35487504009632_CERT.rpl).
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 534.56 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-116FFFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 327C6B67 [RAP Certificate 219 Ver] sent
CMT GENIO_INIT block sent
CMT SOS+IVE3A block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 30.719 s
Processing PPM file: RM-609_111.130.0625_33.01_APAC_1_QW_79_prd.rofs2.fpsx
 [BB5,XSR 1.6]  size: 44.04 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [0CC80000-107BFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 16.032 s
Processing PPM file: RM-609_111.130.0625_C02.02_SEAP_79_prd.rofs3.fpsx
 [BB5,XSR 1.6]  size: 32.37 KB
Erase size: 15.41 MB
CMT FLASH,MuxOneNAND area [01378000-0139FFFF]
CMT FLASH,MuxOneNAND area [107C0000-116FFFFF]
CMT SOS+ROFS3 block sent
CMT SOS+IVE3B block sent
Programming completed in 0.125 s
Processing CNT file: RM-609_APEONLY_eno.fpsx
 [BB5,XSR 1.6]  size: 4.50 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 1.734 s
Processing CNT file: RM-609_111.130.0625_U03.02_79.uda.fpsx
 [BB5,XSR 1.6]  size: 126.73 MB
Erase size: 458 MB
CMT FLASH,MuxOneNAND area [11700000-2E0FFFFF]
Error while programming [00] at 0x11700000, Result: 0000
Is it ok if I select "Erase Whole Flash"?
Old 02-19-2012, 04:08   #2 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
no if you erase whole flash your imei will be lost. what is your phone condition before flash
Old 02-19-2012, 05:05   #3 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Phone status originally was ok, only security locked. But since my mx-box power transistor is not working, I tried to flash it (usb) to reset user code. Now phone won't startup. I've tried to flash the latest firmwares (Moldova & APAC). Flash went thru and got error on the CNT. Dunno why, never come across this kind before on BB5's.
Old 02-19-2012, 06:29   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. first check nxp chip hardware malfunction.
Old 02-19-2012, 09:33   #5 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Yaks, mxbox is at the electronics shop. I'm using usb for flashing. Will bring tomorrow.
Old 02-19-2012, 10:10   #6 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
try fbus cable and flash it with latest version, 111 is outdated.
good luck bro
br
Old 02-19-2012, 12:12   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
good luck bro
br
he is on latest phone firmware version, but his mobileex is old. need to synchronize.
@jabbax: make sure you are using a fully charged battery when doing things on USB
Old 02-19-2012, 12:54   #8 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
hahaha, my mistake, i thought i had 222, but it is 22, just checked on my products
using fbus is better if u have it.
br
Old 02-20-2012, 01:10   #9 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
I tried to Sync but only few files got thru. Others failed. On the "bug", I checked in it seems to be ok.
Gonna try sync again....and again.... and again....
Thanks boys!
Old 01-05-2013, 08:50   #10 (permalink)
Member: 86865
Thanks Meter: 30
Just flash mcu + ppm + ppm2 with ver: 111.140.58, this worked for me, see u...
Old 01-05-2013, 20:39   #11 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Is your Sleep over,
You replying to a Year Old post.
BR,
ZUBER
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
Page generated in 0.24932 seconds with 9 queries
