Unlockvilla Server - Unlocking HUB for resellers/ bulk users/ ebay resellers |
06-29-2011, 13:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: U.K. / INDIA
Member: 1283682 Status: Offline Thanks Meter: 304 | How to Enter Codes in LG Models Start your LG Optimus GT540 Android Phone Click the icon to open the phone dialer Enter 2945#*540# and press send Enter the provided unlock code (which you have purchased) Click ‘Unlock’ , then it’s done. Model : LG GD510 Viewty 1. turn phone on without sim inserted. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945*#510# 4. A menu will pop up, select Unlock Usim 5 Then Select Network Lock 6. Enter your unlock code and press ok 7. The phone will then reboot and the unlock is complete. Model : LG GT505 Viewty 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945*#505# 4. A menu will pop up, select Unlock Usim 5 Then Select Network Lock 6. Enter your unlock code and press ok 7. The phone will then reboot and the unlock is complete. Model : LG KU990 Viewty 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select Unlock Usim 5 Then Select Network Lock 6. Enter your unlock code and press ok 7. The phone will then reboot and the unlock is complete. Model : LG KF900 *****2, KP500, KP550, KP501 Cookie 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code 5. CLICK ON THE ICON ON THE TOP LEFT HAND SIDE OF THE TEXT THEN SELECT THE "SERVICE PROVIDER SIM LOCK" THEN CLICK OK 6. The phone will then reboot and the unlock is complete. Model : LG KS360 1. INSERT ACCEPTED SIMCARD AND TYPE 2945#*71001# 2. GO TO MENU>SETTINGS>SECURITY>SIMLOCK AND ENTER CODE. Model : LG CU920 1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# 3. Message Displayed: SIM Unlock Process 4. Select “OK” 5. Select “Unlock SIM” 6. Select “Network Unlock” 7. Enter the 16 digit unlock code* 8. Select “OK” 9. Re-enter the 16 digit unlock code 10. Select “OK” 11. Device now say: Network Lock Deactivated, Job Done :-) Model : LG KF750 Secret 1. Insert original sim card and turn phone on. 2. Enter 2945#*750# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG TU720 1) Power ON your phone with SIM Card from network that phone is locked to 2) Type *#865625#UNLOCKCODE 3) Press OK 4) Device is now unlocked Model : LG KF600 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : KG800/LG Chocolate 1. Insert working SIM card (sim on original network) 2. Ensure the phone is charged and then switch the phone on. 3. Enter 2945#*7101# while in standby mode 4. Select Menu, then go to Settings > Security > SIM Lock > Network 5. Select Deactivate and enter the 8-digit unlock code provided. 6. The handset will be unlocked automatically and will display "Done". Model : LG KE260 1. insert original sim card and turn phone on. 2. Enter 2945#*2601# 3. A menu will pop up asking for password 4. Enter your unlock code Model : LG KE970 Shine 1. insert original sim card and turn phone on. 2. Enter 2945#*9701# 3. A menu will pop up asking for password 4. Enter your unlock code Model : LG U970 Shine 1. insert original sim card and turn phone on. 2. Enter 2945#*970# 4. A menu will pop up, 5. Select unlock usim 6. Then select network lock 5 Enter your unlock code Model : LG KU990 Viewty 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select Unlock Usim 5 Then Select Network Lock 6. Enter your unlock code and press ok 7. The phone will then reboot and the unlock is complete. Model : LG U400 1. Insert the network SIM in the handset which has given u the lg U400. 2. Enter 256303#*9636# 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 6. It should give you the message Success. 7. Come back to the main screen and Enter 56303#*9636# 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 10. Then press OK. Model : CU400 Insert not allowed SIM card Power on the handset Phone will display "Invalid SmartChip" In Idle screen, enter 159753#*# Phone will display "Enter NCK, Remaining 5" Enter the unlock code Select "OK" the handset is now successfully unlocked Model : CU500 Power on with not allowed sim Type 159753#*# Enter Unlock code Model : CU575 / Trax 1. Put a non cingular sim in the phone ,phone says invalid smart chip 2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code Model : LG U8150 1 - Switch ON your phone with a NOT Allowed SIM Card, 2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #, 3 - Go to menu "SIM Lock", 4 - Enter the Unlock Code we send to you. Model : All other model 1 - Switch ON your phone with an Allowed SIM Card, 2 - Then compose : 2945#*5101# - (if you have a LG 510w) 1945#*5101# - (if you have a LG 1200 & B1200) 2945#*5221# - (if you have a LG 5200 & 52200) 2945#*5301# - (if you have a LG 5300) 2945#*5401# - (if you have a LG 5400) 2945#*70001# - (if you have a LG 7020) 2945#*7101# - (if you have a LG 7100) 2945#*1201# or 2945#*70001# - (if you have a LG 1100) 2945#*70001# - (if you have a LG7250T) 2945#*2201# - (if you have a LG C2200) 2945#*5301# - (if you have a LG T5100) 2945#*3311# - (if you have a LG C3310) 3 - Go to "Menu" and then to "Settings", 4 - Then select "Security", 5 - To finish select "Network Provider" and select "Desactivate" 6 - Enter the Unlock Code we send to you. LG U81xx series ie. 8110, 8120, 8138 etc. turn on phone without sim card inserted. type in 2945#*88110# then unlock USIM should come up press ok then network lock press ok again input network control key comes up enter code Model : LG KB770 1. Power on phone with original SIM card 2. Type 2945*#770# 3. In the menu that appears select Sim unlock 4. Enter supplied unlock code 5. Your phone is unlocked Model : LG KP170 1 - Switch ON your phone with a T Mobile Sim inserted 2 - Press telephone icon at bottom of screen to bring up the phone keypad 3 - Then compose : 2945#*170# 4 - A menu will pop up, select Unlock Usim 5 - Then Select Network Lock 6 - Enter your unlock code and press ok (you only have 10 attempts) 7 - The phone will then reboot and the unlock is complete. Model: LG CU-515 1.Put a SP-locked sim in the phone, phone say invalid smart chip 2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code Phone will be unlocked! Model : LG TE365 1. Power on phone with original SIM card 2. Type *#0001#code# 3. Your phone is unlocked Model : LG CT810 (Incite) 1. Power on phone with original SIM card 2. Type 2945#*810# 3. In the menu that appears select Sim unlock 4. Enter supplied unlock code 5. Your phone is unlocked Model : LG CB630 (Invision) 1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2) Dial this into the LG Incite's phone menu 3) *#865625# 4) Press CALL. 5) It should you ask you for the code. Model : LG U830 1. Have your unlock code handy. 2. InserI a 3 SIM card in the phone and switch power on. 3. Enter the following key sequence 94471877#*# 4. Select the option ‘unlock USIM’. 5. Select the option ‘network unlock’ 6. Enter your unlock code. 7. Handset should now display ‘network unlock success’. 8. Handset will now restart. Model : LG KF300 1. Put wrong simcard 2. Phone alert 'insert correct card' 3. Right under in screen you see deblokkeren (dutch) 4. Click on it en click 'Network lock off' 5. Insert code! Model : LG KP100 1. Insert original sim card and turn phone on. 2. Enter 2945#*20001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF755d 1. Insert original sim card and turn phone on 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work) 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete Model : LG Incite CT-810 - Insert a SIM from the original network - 2945#*810# will show the unlock menu - Enter unlock code Model : LG KP265 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*265# 3 - Then go to MENU > SETTINGS > SECURITY 4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE 5 - ENTER NCK (your Unlock Code) Model : LG ME550 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*71101#. 3 - Menu will appear, go to settings > security > sim lock 4 - Enter NCK ( Unlock Code ) and press OK. Model : LG TU915 - Switch ON your phone with an allowed SIM Card - Then compose: 2945#*9701# - It should you ask you for the code. OR Enter *#865625# then enter your 16 digits code. Model : LG KF390 and KF390q 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Select ok. Done! Model : LG *****, KE850 : 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked Model : LG CT810 1. insert original sim card and turn phone on. 2. Enter 2945#*810# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG VU CU915 & CU920 (Vu) 1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked ! Model : LG U310 1. Turn ON the phone without SIM Card : 2. Enter 815118#*# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF700 (aka LG Virgo) 1. insert original sim card and turn phone on. 2. Enter 2945#*700# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KC910, KF910 (aka LG *****) 1. insert original sim card and turn phone on. 2. Enter 2945#*910# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF750 1. insert original sim card and turn phone on. 2. Enter 2945#*750# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF600 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG U970 1. Insert original sim card and turn phone on. 2. Enter 2945#*970# 3. A menu will pop up, select Unlock Usim. 4. Select Network Lock. 5. Enter the unlock code and ok. Model : LG U300 1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider) 2 - Enter Code : 815118#*# 3 - then phone will ask to enter NCK Model : LG C2000: 1) Insert non-Cingular SIM card 2) Power on the handset - phone will display "phone restricted" 3) Select "Cancel" - phone will display "phone restriction code" 4) Enter the SIM Unlock code 5) Select "OK" - the handset is now successfully unlocked Model : LG KU990 Viewty & KE990 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete. Model : LG TU720 - LG CU720 (Shine) 1) Power ON your phone with not allowed sim card (one that didn't come with the phone) 2) Type *#865625# 3) the phone will ask you to input the unlock code twice, just input the unlock code 4) Device is now unlocked Model : LG CE110 1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK’" - the handset is successfully unlocked Model : LG GR500 (Xenon) 1) Insert not-allowed SIM card 2) Power on the handset- phone will display "phone restricted" 3) Select "Cancel" - phone will display "phone restriction code" 4) Enter the SIM unlock code 5) Select "OK" - the handset is now successfully unlocked or 1. insert original sim card and turn phone on. 2. Enter 2945#*9701# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG CU320 1) Power on the handset 2) In Idle screen, input the special code "277634#*#". 3) Enter the SIM Unlock code 4) Access the submenu "SIM Test" in Phone Test Mode. 5) Input the special code "2945#*#". 6) Access the submenu "SIM Unlock" which is just activated after the special code. 7) Input the 8-digit Unlock code in the "Enter unlock code" input screen. 8) It will be unlocked. Model : LG CU400 & CU405 1) Insert non-Cingular SIM card" 2) Power on the handset - Phone will display "Invalid SmartChip". 3) Enter 159753#*# 4) Enter the 8 digit SIM Unlock code 5) Select "OK". 6) The handset will be unlocked. Model : LG CU500 1) Insert non-Cingular SIM card. 2) Power on the handset. Phone will display "Invalid SmartChip" 3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 5) Enter the 8 digit SIM unlock code 6) Select "OK" 7) The handset is now successfully unlocked. Model : LG CU515 1) Insert non-Cingular SIM card 2) Power on the handset - Phone will display "Invalid SmartChip". 3) Enter *#865625# then select option 1 and then again select 1 4) Enter the 16 digit SIM Unlock code 5) Device should say: Network Lock Deactivated 6) The handset is unlocked. Model : LG CU515 (Trax) 1) Put a non-Cingular sim in the phone 2) Phone says invalid smart chip 3) Now enter *#865625# then select option 1 and then again select 1 4) Enter your 16 digits code 5) Device should say: Network Lock Deactivated 6) The handset is unlocked. Model : LG U8150 1 - Switch ON your phone with a NOT Allowed SIM Card, 2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #, 3 - Go to menu "SIM Lock", 4 - Enter the Unlock Code we send to you. Model : LG U400 1. Insert the network SIM in the handset which has given u the LG U400. 2. Enter 2945#*88110#. 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 6. It should give you the message Success. 7. Come back to the main screen and Enter 2945#*88110#. 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 10. Then press OK Model : All other model 1 - Switch ON your phone with an Allowed SIM Card, 2 - Then compose : 2945#*5101# - (if you have a LG 510w) 1945#*5101# - (if you have a LG 1200 & B1200) 2945#*5221# - (if you have a LG 5200 & 52200) 2945#*5301# - (if you have a LG 5300) 2945#*5401# - (if you have a LG 5400) 2945#*70001# - (if you have a LG 7020) 2945#*7101# - (if you have a LG 7100) 2945#*1201# or 2945#*70001# - (if you have a LG 1100) 2945#*70001# - (if you have a LG7250T) 2945#*2201# - (if you have a LG C2200) 2945#*5301# - (if you have a LG T5100) 2945#*3311# - (if you have a LG C3310) 3 - Go to "Menu" and then to "Settings", 4 - Then select "Security", 5 - To finish select "Network Provider" and select "Desactivate" 6 - Enter the Unlock Code we send to you. Model : To Classify For the next models u must to insert the original SIM: LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KE970 press 2945#*9701# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KG800 press 2945#*7101# LG KU250 press 2945#*250# LG KU380 press 2945#*380# After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK. For next models insert one SIM ,not the original SIM: LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG U400 press 2945#*88110# LG KC550 press 2945#*71001# LG KU580 press 2945#*580# LG KT520 press 2945#*520# LG KF750 press 2945#*750# LG KF600 press 2945#*71001# LG KG275 press 2945#*20001# LG KU380 press 2945#*380# LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KS500 press 2945#*500# LG KP270 press 2945#*270# LG KF240 press 2945#*240# or 2945#*2401# LG KG290 press 2945#*7101# LG KU250 press 2945#*250# Last edited by C Singh; 06-29-2011 at 13:34. |
The Following User Says Thank You to C Singh For This Useful Post: |
06-29-2011, 13:37 | #2 (permalink) |
Member: 1283682 Status: Offline Thanks Meter: 304 | LG P500 Optimus 2945#*500# LG KB770 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" The phone will then reboot and the unlock is complete LG GB250, GB220 Power on your phone without SIM card Enter 2945#*71001# From the menu that pops up select "SIM unlock" The phone will then reboot and the unlock is complete LG GT505 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" The phone will then reboot and the unlock is complete LG BL40 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*40# From the menu that pops up select "SIM unlock" Enter unlock code The phone will then reboot and the unlock is complete LG BL20 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*20# From the menu that pops up select "SIM unlock" Enter unlock code The phone will then reboot and the unlock is complete LG GW520, GB250 Insert an original simcard and turn phone on (code can also be entered without SIM card) Enter sim PIN if required Enter 2945#*71001# From the menu that pops up select "SIM unlock" Enter unlock code The phone will then reboot and the unlock is complete LG Viewty GW300 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*700# From the menu that pops up select "SIM unlock" Enter unlock code The phone will then reboot and the unlock is complete LG G910 Insert a non original simcard and turn phone on Enter sim PIN if required Select "Emergency mode" Enter 2945#*71001# Sim unlock mode pop up Select Netlock Enter unlock code The phone will then reboot and the unlock is complete To enter unlock code for LG P990 You need: 1. Insert the sim card which works out your phone 2. Enter 2945#*990# 3. window appears for the code 4. Enter the code nck received 5. the phone is unlocked Enter Codes in LG T310/ Cookie Style Enter as always 2945#*310# and it will take u in for enter code Lg s310 ...... just enter 2945#*310# Then it gave me two options Network unlock Service provider unlock select the option &enter the code...... Lg a133 .. power phone ON with original network sim - type 2945#*133# to enter unlock menu - enter needed unlock code |
06-30-2011, 22:40 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Scotland
Member: 50067 Status: Offline Thanks Meter: 40 | I thought I would add this in case it helps anyone..... I just unlocked LG GD510 (POP) Handset was locked to Tesco-UK The handset was asking for SPCK. When I entered SPCK the code was wrong. I tried NCK and phone unlocked So in short - If SPCK doesnt work, try NCK (in SPCK box) MK5. ps I used 2945#*510# the code sequence for the 2nd & 3rd handsets at the top of this thread (GD510 & GT505) have a slight error. Sequence should begin 2945#* - NOT 2945*# |
03-05-2018, 23:45 | #4 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2818226 Status: Offline Thanks Meter: 0 | LG android pattern did not work, wrong pin, how to reset it from google? My Virgin Mobile is in LG ls450, I used pattern as usual but it did not take it and then it told put pin, I put it on and it says it is wrong. How I reset without factory setting? |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
