Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Unlockvilla
Old 05-08-2009, 08:43   #1 (permalink)
Member: 580966
Sonork: 100.1590311
Smile How to enter unlock codes
BLACKBERRY
Unlock Instruction for Blackberry Storm (9500)
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keybord
7. Enter mepd (you will not be able to see the typed info)
8. Enter mep2
9. Now it will say enter network mep code
Unlock Instruction for blackberry 8300 series, 8800 series, Bold n9000
***** You must have a SIM card in your phone to complete these steps ( Can be active or inactive ) *****
1) Go to Settings Menu => and then Options
2) Select Advanced options => and then Sim Card
3) Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on nthe screen while typing MEPD)
4) Type MEP then [ALT BUTTON] then 2 on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEP2)
5) You should be presented with a prompt "Enter Network MEP Code".
6) Enter the Unlock Code
7) Press Enter (You can use the track ball as well)
8) Device is now unlocked
Unlock Instruction for Blackberry 8100 Pearl
***** You must have a SIM card in your phone to complete these steps (Can be active or inactive) n*****
5) Type MEPPD (NOTE: You will not see any text appear on the screen while typing MEPPD)
6) Type MEPP then [ALT BUTTON] then 2 (NOTE: You will not see any text appear on the screen while typing nMEPP2)
Unlock Instruction for Blackberry 8700
***** You must have a SIM Card in your phone to complete these steps, (Can be active or inactive) n*****
3) Type MEPD using your Blackberry keyboard n(NOTE: You will not see any text appear on the screen while typing MEPD)
Unlock Instruction for BlackBerry 6xxx 7xxx: ie 6230, 7100, 7290 etc..
3) Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) for all models, except 7100 will have to Type MEPPD
4) Type MEP then [ALT BUTTON] then 2 on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEP2) for all models, except 7100 will have to Type MEPP2
7) Press Enter n(You can use the track wheel as well)
HTC & GOOGLE G1 Pantech, Cingular, HP, 8525, 3125, 2125 & all Windows Smartphones, Windows Pocket PC Phones
Unlock Instruction for HTC S621, HTC Touch, HTC TYTN
1) Power ON your phone with different SIM Card then the phone is locked to
2) Enter UNLOCK CODE
3) Device is now unlocked n
Unlock Instructions for SPV C500
1 - Switch ON mobile with a not Allowed SIM Card,
2 - The message "PUK2" appear,
3 - Enter the Unlock Code we send to you.
4 - Phone ASK for New Code PIN enter : 0000
5 - Confirm and compose : 0000**
6 - Click "Finish" and phone will show "Network is locked..."
7 - Enter the Unlock Code we send to you and click "Finish"
8 - Restart the Mobile who is Unlocked !
LG
Unlock Instruction for LG U8150
2) Type 277634#*#
3) Go to Menu "SIM Lock"
4) Enter Unlock Code
5) Device is now unlocked
Unlock Instruction for LG KG800 or TG800
2) Type 2945#*7101#
3) Go to Menu "Setting"
4) Go to Menu "Security"
5) Go to Menu "SIM Lock"
6) Go to Menu "Network"
7) Go to Menu "Deactivate"
8) Enter Unlock Code
9) Device is now unlocked
Unlock Instruction for LG TU720
1) Power ON your phone with Rogers SIM Card
2) Type *#865625#UNLOCK CODE
3) Press OK
4) Device is now unlocked
Unlock Instruction for LG CU500
2) Type 159753#*#
3) Phone will display "Enter NCK"
Unlock Instruction for all LG
2) If your phone is:
LG 510w then Type 2945#*5101#
LG 1200 & B1200 then Type n1945#*5101#
LG 5200 & 5220 then Type n2945#*5221#
LG 5300 then Type 2945#*5301#
LG n5400 then Type 2945#*5401#
LG 7020 then Type n2945#*70001#
LG 7100 then Type 2945#*7101#
LG 1100 then Type 2945#*1201 or 2945#*70001#
LG 7250T then Type 2945#*70001#
LG C2200 then Type n2945#*2201#
LG T5100 then Type n2945#*5301#
LG C3310 then Type n2945#*3311#
3) Go to Menu and then Setting
4) Select Security
5) Select Network Provider
6) Select Deactivate
7) Enter Unlock Code
NOKIA
***** DO NOT enter the unlock code more than 3 times on BB5 phones, if you do you will NEVER be able to unlock your phone by code *****
2) Type #PW+CODE+1# using your keyboard
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3) The phone will show "SIM Restriction Off," in case it doesn't unlock the phone, you will have to replace step 2 but use 7 instead of 1
*** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
Substitute the 1 at the end with 7.
So 2nd time try: #PW+YOURCODE+7#
ie. #pw+000000000000000+7#
The letter P appears after you quickly press 3 times the button star ( * )
The letter W appears after you quickly press 4 times the button star ( * )
The letter + appears after you quickly press 2 times the button star ( * )
The phone shows "SIM Restriction Off" and is unlocked!
MOTOROLA
Unlock Instruction for Motorola
Note: If your phone is a 3G phone enter **057*, then another window will appear and ask for the subsidy password.
WARNING: if any of these messages appear :
- "Contact Service Provider"
- or "Tamper Alter"
- or "Wait Before Enter Special Code"
- or "Contact Service'
It's because you or somebody else has already entered too many wrong codes. You just have to leave the phone ON on the error message and after n1hr - 8hrs the message "Enter Special Code" will appear again!
Note: If your phone is on a 3G network enter **057*, then another window will appear to enter the unlock code.
SAMSUNG
Unlock Instruction for Samsung 3G, Zxxx & Dxxx, A707 Series
1) Power ON your phone without SIM Card
2) Type n#7465625*638*UNLOCK CODE#
Unlock Instruction for Samsung Z105 and Z107
2) Type # n7465625*638*UNLOCK CODE#
Unlock Instruction for Samsung Z510 and Z320i
2) Type **UNLOCK CODE#
Unlock Instruction for Samsung ZX10, ZX20, A707, X497, and C417
2) Type #7465625*638*UNLOCK CODE#
SIDEKICK
Unlock Instruction for Sidekick or Hiptop
2) The phone will prompt for unlock code
3) Enter UNLOCK CODE
SONY ERICSSON
Unlock Instruction for Sony Ericsson
2) Press 1 time the left arrow ( < )
3) Press 2 times the button *
4) Press 1 time the left arrow ( < )
5) "Personalize with MNC2" will appear
7) Device is now unlocked
The Following 2 Users Say Thank You to KK Mobile For This Useful Post:
Old 05-08-2009, 10:49   #2 (permalink)
Member: 580966
Sonork: 100.1590311
Smile
Model : AlcatelModel : 531 - 535
Without sim card : holding the "*" and compose 787292
menu "unlock network" activated select YES and enter recived code
Other model
- Switch on your phone with a not accepted SIM Card,
- When the message "Enter Network Key" appear enter the Code recived
Model : Method Generic
1 - Switch ON your phone without SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
Sagem All
1 - Switch ON your phone with a not Allowed SIM Card,
2 - Phone will show "SIM VERROU"
3 - You can now enter the Unlock Code.
Note: if your mobile show "CODE POSTE" it's because you have a Security Code, can be 0000 or 1234 but we can't calculate this code with your IMEI because it's not code from Phone but code from the User of the Phone !
Sagem My-S7
2 - Compose : *#*#CODE# and press "Call" button.
Vodafone
ZTE 125 125FM 225 225 FM 226 226 FM 527 526
2 - Enter Unlock Code we send to you.
810 716
2 - GO TO NCK BY OPTION KEY
3 - Enter Unlock Code we send to you
NEC......
Model : Nec N342i
2 - Compose : **00012*CODE#.
Model : All others NEC
2 - Compose : #7320*CODE#.
Model : old NEC
2 - Compose : #3210*CODE# and press Call Button.
The Following User Says Thank You to KK Mobile For This Useful Post:
How to enter unlock codes in samsung s3650, not accept codes when i enter,why? svchost NSPRO 21 02-16-2012 15:21
Cable Finder + Secret Code + How to Enter Unlock Code V 1.6 Ready !!! mughalG Universal GSM Software 18 11-23-2010 04:34
how to enter unlock code in modem after getting unlock code from MXKEY (Answered) NAVEED74 MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker 1 03-06-2010 13:25
************* How to enter unlock codes -=- How to Master Reset & More************ F C Xpresscodes.com 4 06-09-2009 01:58
[FAQ] Code by IMEI : How to enter Unlocking Code on my Mobile Phone ? UnlockBase.com UnlockBase 93 08-06-2008 14:59
Page generated in 0.26090 seconds with 11 queries
