02-22-2011, 09:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | ٩(●̮̮̃•All Successful Stories of Master Box with Huawei, ZTE, Ufone, Zong, LG, Airtel Now press Power-on button of the mobile BBCHIP: "MT6223_S00", EXT_26 CODE(0x6223), VER(0x8A05), SW(0x8A00) NOR_DETECTION: "S_DONE"(0) NOR_ID: "[TOSHIBA] TC58FVM7TDD" NOR_ID: 0x0098, 0x0003, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 128Mb (0x01000000) NAND_DETECTION: "S_DA_NFI_NOT_SUPPORT"(3047) NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 0Mb (0x00000000) EXT_RAM_DETECTION: "S_DONE"(0) EXT_RAM_TYPE: "SRAM" EXT_RAM_CHIPSEL: "CS1" EXT_RAM_SIZE: 32Mb (0x00400000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 320Kb (0x0000A000) Reading flash Reading Flash Successfully! Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6223, E05 Software Version : G3610_V100R001B001C19SP03S Unlock Successfully! Last edited by AsiaGSM™; 02-24-2011 at 10:58. |
The Following 16 Users Say Thank You to M.AKHTER For This Useful Post: |
02-23-2011, 15:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | BooM Rocking UFONE G3610 UNLOCK DONE CPU:6223 RX: 9 TX: 7 Scanning successfully!: Now press Power-on button of the mobile BBCHIP: "MT6223_S00", EXT_26CODE(0x6223), VER(0x8A05), SW(0x8A00) NOR_DETECTION: "S_DONE"(0)NOR_ID: "[ST] M30L0T7000T0, M36L0T7050T0" NOR_ID: 0x0020, 0x88C4, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 128Mb (0x01000000)NAND_DETECTION: "S_DA_NFI_NOT_SUPPORT"(3047)NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 0Mb (0x00000000)EXT_RAM_DETECTION: "S_DONE"(0)EXT_RAM_TYPE: "SRAM" EXT_RAM_CHIPSEL: "CS1" EXT_RAM_SIZE: 32Mb (0x00400000)INT_SRAM_DETECTION: "S_DONE"(0)INT_SRAM_SIZE: 320Kb (0x0000A000) Reading flash Reading Flash Successfully! Now press Power-on button of the mobile BBCHIP: "MT6223_S00", EXT_26CODE(0x6223), VER(0x8A05), SW(0x8A00) NOR_DETECTION: "S_DONE"(0)NOR_ID: "[ST] M30L0T7000T0, M36L0T7050T0" NOR_ID: 0x0020, 0x88C4, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 128Mb (0x01000000)NAND_DETECTION: "S_DA_NFI_NOT_SUPPORT"(3047)NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 0Mb (0x00000000)EXT_RAM_DETECTION: "S_DONE"(0)EXT_RAM_TYPE: "SRAM" EXT_RAM_CHIPSEL: "CS1" EXT_RAM_SIZE: 32Mb (0x00400000)INT_SRAM_DETECTION: "S_DONE"(0)INT_SRAM_SIZE: 320Kb (0x0000A000) currently format mode: Auto Format FAT Please Press power on key! BBCHIP: "MT6223_S00", EXT_26CODE(0x6223), VER(0x8A05), SW(0x8A00) NOR_DETECTION: "S_DONE"(0)NOR_ID: "[ST] M30L0T7000T0, M36L0T7050T0" NOR_ID: 0x0020, 0x88C4, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 128Mb (0x01000000)NAND_DETECTION: "S_DA_NFI_NOT_SUPPORT"(3047)NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 0Mb (0x00000000)EXT_RAM_DETECTION: "S_DONE"(0)EXT_RAM_TYPE: "SRAM" EXT_RAM_CHIPSEL: "CS1" EXT_RAM_SIZE: 32Mb (0x00400000)INT_SRAM_DETECTION: "S_DONE"(0)INT_SRAM_SIZE: 320Kb (0x0000A000) Format successful! Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6223, E05 Software Version : G3610_V100R001B001C19SP03S Unlock Successfully! AFTER UNLOCK IT ASK FOR NP(NETWORK PROVIDER) ENTER 12345678 for download flash file click here.... [IMG]http://**********.pk/images/arx1298209774z.PNG[/IMG] Last edited by malikasim; 02-23-2011 at 15:14. |
The Following 15 Users Say Thank You to malikasim For This Useful Post: |
02-27-2011, 09:08 | #3 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | onther ufone hawei g3610 unlock done with master box Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6223, E05 Software Version : G3610_V100R001B001C19SP03S Unlock Successfully! |
The Following User Says Thank You to M.AKHTER For This Useful Post: |
03-05-2011, 09:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | huawei G 3610(ufone) unlock done by master tool........... huawei G3610 (ufone) unlock done Readflash:. CPU:6223 RX: 9 TX: 7 Scanning successfully!: Now press Power-on button of the mobile BBCHIP: "MT6223_S00", EXT_26 CODE(0x6223), VER(0x8A05), SW(0x8A00) NOR_DETECTION: "S_DONE"(0) NOR_ID: "[TOSHIBA] TC58FVM7TDD" NOR_ID: 0x0098, 0x0003, 0x0000, 0x0000 NOR_CHIPSEL: "CS0" NOR_SIZE: 128Mb (0x01000000) NAND_DETECTION: "S_DA_NFI_NOT_SUPPORT"(3047) NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_CHIPSEL: "NFICS0" NAND_SIZE: 0Mb (0x00000000) EXT_RAM_DETECTION: "S_DONE"(0) EXT_RAM_TYPE: "SRAM" EXT_RAM_CHIPSEL: "CS1" EXT_RAM_SIZE: 32Mb (0x00400000) INT_SRAM_DETECTION: "S_DONE"(0) INT_SRAM_SIZE: 320Kb (0x0000A000) Reading flash Reading Flash Successfully! unlock done:. Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6223, E05 Software Version : G3610_V100R001B001C19SP03S Unlock Successfully! AFTER UNLOCK IT ASK FOR NP(NETWORK PROVIDER) ENTER 12345678 thanks mastertool team br:. shabir97 |
The Following 2 Users Say Thank You to shabir97 For This Useful Post: |
03-09-2011, 12:08 | #5 (permalink) |
No Life Poster Join Date: Nov 2010 Location: pakistan
Member: 1453428 Status: Offline Sonork: 100.1596919 Thanks Meter: 146 | also done by me via master box here is unlocking log Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6223, E05 Software Version : G3610_V100R001B001C19SP03S Unlock Successfully! regards iqa_shaheen |
03-30-2011, 14:09 | #6 (permalink) |
Freak Poster Join Date: Feb 2007 Location: karachi pakistan.
Member: 456367 Status: Offline Sonork: 100.1613650 Thanks Meter: 94 | Ufone huawei G5500 Unlock successfully in Master tool Ufone huawei G5500 Unlock successfully in Master tool Currently format mode:UnLock clean multimedia! Now press Power-on button of the mobile Base Band Chip : MT6253, S00 Software Version :MT6253_S00.W1_1PU01V01_04.BIN Unlock Successfully! Please Press power on key! Writing imei1 successfully! Write IMEI successfully! used to master tool ver,6.6.0 1st format 2nd unlock 3rd change imei, Right imei in the back of phone now u cell is unlock successfully! Enjoy... |
The Following 15 Users Say Thank You to msarfraz For This Useful Post: |
05-20-2011, 17:11 | #7 (permalink) |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | ZOng zte-g r221 UNLOCK DONE BY MASTER BOX :) zong zte-g r221 UNLOCK DONE BY MASTER BOX As Every Body Know Master Box is A Unique Tool it works for many Branded MTK based Phones with only 1 exe this Phone Done on OLD database and New Database will Blast soon How To: 1. Connect Phone With Master Box 2. Scan COM 3. read info 4. Format Phone 5. Unlock Phone 6. Change IMEI(you can get IMEI on Back Label of Phone) All Done Video: Last edited by AsiaGSM™; 05-21-2011 at 11:07. |
The Following 15 Users Say Thank You to AsiaGSM™ For This Useful Post: |
05-23-2011, 13:05 | #8 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Airtel FGD8900 One click Unlock don :) Hi to Mastertool users Good news in our Mastertool U can unlock Airtel FGD8900 unlock easy No need Format No need imei change Just Press unlock button Thats all Wbr Azeem |
The Following 5 Users Say Thank You to .::AZEEM::. For This Useful Post: |
05-30-2011, 12:42 | #9 (permalink) |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Another Zte G-R221 8mb unlock Oki Just flash this file Ur phone will be Unlocked Version :- MT6223_S00.TMO_UK_P109A17V1_0_1B07.BIN Zte-G-R221 8Mb |
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post: |
06-09-2011, 15:12 | #10 (permalink) |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Spice D6666 2gsm 1Cdma Fully Supported In Mastertool Remember its old database New one Come Soon more powerfull Last edited by .::AZEEM::.; 06-24-2011 at 07:49. |
The Following 10 Users Say Thank You to .::AZEEM::. For This Useful Post: |
06-14-2011, 10:55 | #12 (permalink) |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Who one sys Lg phones not work in Mastertool Lg Gx200 Fully supported Im happy to sys in mastertool Old database mtk tool its more powerfull Lg Gx200 2sims Nand Flash type Fully supported on Mastertool Before some days Ago some one sys me lg all fones not work in Mastertool Its not right All lg Phones supported Im tested Some units Work like Chrams Here is Video Proof Remember its old database New one Come Soon more powerfull |
The Following 4 Users Say Thank You to .::AZEEM::. For This Useful Post: |
06-30-2011, 14:33 | #14 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | LG KP109 Fully Supported in MasterBox Last edited by AsiaGSM™; 07-01-2011 at 11:41. |
The Following 7 Users Say Thank You to LuisinhoCell For This Useful Post: |
07-04-2011, 14:48 | #15 (permalink) |
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | All Successful Stories of Master Box with Huawei, ZTE, Ufone, Zong, LG, Airtel Last edited by AsiaGSM™; 08-01-2011 at 16:36. |
The Following 3 Users Say Thank You to LuisinhoCell For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
