Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Mastertools
Old 12-04-2012, 14:18   #1 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Thumbs up Coolsand Usb Facts
CoolSand Usb method :
  • USB only work with mobile can power on ,if your mobile can’t power on ,please use COM Port
  • PinFinder Can't work for CoolSand USB Port
  • need use original USB cable for access mobile's U-disk
  • need select Flash Model manual
  • need install driver when first use
  • after select Flash Model manual ,click “read ” ,“write”,”IMEI” or “Password”.interface will show
Information as :
Power Off you mobile and keep battery installed in mobile, Connect the USB cable
Wait your mobile show :
At this time keep press “0”key until the mobile show:
Now its ask drivers :
How to install driver for CoolSand USB
  • Connect your mobile with usb cable
  • When mobile’s LCD show “Mass Storage”, (If LCD not show than check Ur usb cable )
  • keep press the “0” key
  • In your mobile will show “Open Usb download”,
  • At the same time your computer will find new hardware
  • now install CoolSand usb driver in your computer Manually
  • it located in “C:\Program Files\MasterBox\Driver\CoolSand”,
If you have install usb driver correct,in your computer’s Device Manager,show information as below
If u do all process like this finally u see like this work
Here is all videos how to work :
Coolsand usb write flash
http://www.youtube.com/watch?v=6oHLB6AuTxE
Coolsand usb read password
http://www.youtube.com/watch?v=sdq1lR20fO8
Coolsand Usb read flash
http://www.youtube.com/watch?v=qZ3-KvrOVs8
Coolsand Usb imei Change
http://www.youtube.com/watch?v=dKKMj06T-Sw
The Following 9 Users Say Thank You to .::AZEEM::. For This Useful Post:
Old 12-04-2012, 14:23   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Again Mastertool box being Rock
Old 12-04-2012, 14:29   #3 (permalink)
fiazahmad's Avatar
Member: 263277
Thanks Meter: 142
pasword reading problem conect read flash ok not read pasword
Old 12-04-2012, 15:05   #4 (permalink)
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Seem's like communication problem
The Following User Says Thank You to .::AZEEM::. For This Useful Post:
Old 12-05-2012, 08:54   #5 (permalink)
Member: 1726229
Thanks Meter: 223
I tried many time chnge imei software Always says imei write suscees but in set old imei
The Following User Says Thank You to Ahsaan* For This Useful Post:
Old 12-05-2012, 09:03   #6 (permalink)
PUNEET5154's Avatar
Member: 1023528
Sonork: 100.1594367
Thanks Meter: 1,376
FIRST UPDATE TO 3.30
MasterBox Firmware UpgradeFor HW 1.0 FW3.30.rar - 4shared.com - online file sharing and storage - download?
Use My Updater And For Firware Go To C:\Program Files\MasterBox\pinfinder\Firmware.dat
And Select Fimware.dat 144 kb in pinfinder folder and update 100% after update firmware 3.30 Tested On 10 Users.
Puneet5154-Mastertools
The Following User Says Thank You to PUNEET5154 For This Useful Post:
Old 12-05-2012, 10:35   #7 (permalink)
Member: 1726229
Thanks Meter: 223
I done firmware update but imei problem not solve
Old 12-05-2012, 14:31   #8 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
Sir for me didnt work still want to upgrade firmware now its firmware is 3.29
Old 12-05-2012, 15:05   #9 (permalink)
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
http://forum.gsmhosting.com/vbb/8990566-post4.html
Old 12-05-2012, 21:26   #10 (permalink)
Maik_TechService's Avatar
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
Question what happen after get no update?
Originally Posted by .::AZEEM::. View Post
hi bro what happen after box don't success to update 3.30
no other ways for that?
Old 12-05-2012, 21:37   #11 (permalink)
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
Unhappy hi good job but just need really answer?
[QUOTE=.::AZEEM::.;8988669]
Information as :
[/QUOTE
I AM SO SORRY TO ASK THIS QUESTION WHY FOR THIS GOOD AND APPRECIATE UPDATE YOU GIVE GOOD INSTRUCTION HOW TO USE PERFECTLY COOLSAND CPU OR OTHER UPDATE NO WAY TO KNOW WELL HOW TO USE OTHER INTERFACE
PLEASE I AM BEEGING YOU TO THINK ABOUT IT THIS IS REQUEST PLEASE SHOW TO SOME OUR USER TO USE PERFECLTY THIS GREAT MASTER BOX
REGARD
MAIK_TECHSERVICE
Old 02-20-2018, 09:49   #12 (permalink)
Member: 2761429
Can't i get the drivers manually without master box?
Page generated in 0.21528 seconds with 8 queries
